Author Topic: Airbox Conundrum  (Read 607 times)
Rlint
Airbox Conundrum
« on: June 20, 2010, 01:15:29 PM »
So I bought a new air filter, a uni foam filter, pop up the seat, go to switch 'em, pry the old element out (which is was shockingly difficult), and find... nothing.  Literally, nothing at all in the airbox.  PLUS, it's a 74 550, and the airbox is marked "CB550F". Neither the element I pulled out nor the one I purchased for it appears to fit properly in the box without having something under it...
So, my thought for quick, get-it-back-on-the-road fix was foam, or a sponge, or something under it, and a spring on the side of the box nearest the rear-wheel to hold it in place.  Seems like that would work, but it's also not proper, so what exactly am I missing?  Anywhere to get an entire air-box setup?  Who's got pods and doesn't need their airbox?
Offline Kevin400F
Re: Airbox Conundrum
« Reply #1 on: June 20, 2010, 03:26:10 PM »
Go to an online microfiche such as the one at:
http://www.mrcycles.com/fiche_section_detail.asp
and look up the parts you're missing.
« Reply #2 on: June 20, 2010, 03:30:25 PM »
The 550 air filter box was originally designed for the CB550F.  ASAIK all the 550s use the same air filter box with the 550F casting numbers on it.
For the parts you are missing see:
http://www.cmsnl.com/honda-cb550k0-four-usa_model465/partslist/F++05.html
