Author Topic: Need help reassembling '76 CB550F carbs carburetors  (Read 1780 times)
Offline jorwesflow
  • we're not schizophrenic
« on: June 21, 2010, 10:47:20 AM »
I'm a total noob and just purchased a '76 CB550F, my first bike. I took the carbs off, disassembled them, cleaned them really nice, and now have them almost completely back together. My problem is that the Owner's Manual and the Clymer manual do no really go into detail about the "link arm" (I think that's what it's called—the thing that links the four carbs together). Well I have these four rubber pieces (see pic) and I can't remember where they go. Any help is appreciated.
« Last Edit: June 21, 2010, 10:49:25 AM by jorwesflow »
1977 CB550K
Offline fastbroshi
  • Puppet
Re: Need help reassembling '76 CB550F carbs carburetors
« Reply #1 on: June 21, 2010, 10:56:41 AM »
Not the best pic, but you can see them here aligned vertically beside each post that have the big brass caps
Just call me Timmaaaaay!!!
Offline jorwesflow
« Reply #2 on: June 21, 2010, 11:29:43 AM »
thanks, that helps a TON!
another question...
one of the two "adjuster holders" (as the clymer manual calls it)(see the pic) was snapped in half when i received the bike... how crucial are they to the function of the carbs? I can't find a replacement online anywhere...
1977 CB550K
« Reply #3 on: June 21, 2010, 11:37:18 AM »
The engine will run without them.  What you may lose is fine carb sync at idle, and possibly loose adjusters over time.  Also, the ball sockets in the linkage can wear unevenly.
Why would you think that Honda would put parts on a bike and add cost if it served no purpose?
You can drive the bike without gas, too.  Just arrange to have your destination always downhill.  ;D
Offline jorwesflow
« Reply #4 on: June 21, 2010, 11:51:06 AM »
any ideas where i can find an adjuster holder? i've looked on bike bandit, but the drawings are so low quality, it's impossible to pick out which part i need. not to mention, i think they have it listed with a different name.
1977 CB550K
Offline jorwesflow
« Reply #5 on: June 21, 2010, 12:47:31 PM »
i feel like such a tool having to post pictures of stray parts and ask where they go... nonetheless, here's another one. i have four lock washers with a 3/16" inner diameter that i have no idea where they go on the carb assembly. i know it's not internal, because every single part on the clymer manual diagram was accounted for. i am convinced they belong on something external on the carbs. Any ideas?
And also that cylindrical piece... does that look familiar to anyone?
Thanks for the help!
1977 CB550K
« Reply #6 on: June 21, 2010, 12:56:22 PM »
The barrel part is the throttle return spring perch, which fits between carbs 2&3.  It is inserted while reassembling the carb bank.
As for lock washers.  Look at your carbs.  Which screws don't have lock washers on them now?
Offline jorwesflow
« Reply #7 on: June 21, 2010, 01:19:39 PM »
TwoTired, does the spring perch look like it's in the right spot now? (see pic)
As for the lock washer, the Clymer manual shows that lock washers (#8, see pic)) go on the float bowl screws. But seeing as there are four screws per float bowl X four bowls, that = 16 lock washers...but i have 4 here. does that mean each float bowl has only 1 of 4 of its screws with a lock washer?
1977 CB550K
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« Reply #8 on: June 21, 2010, 01:49:27 PM »
Stator covers?
Its hard to be wrong when you know nothing!
« Reply #9 on: June 21, 2010, 05:36:17 PM »
Yes, I think so.
All the bowl screws are supposed to have lock washers.  I can't think of many fasteners on the bike that don't have an anti-vibration device of some kind to keep them in place.  Not good to have things fall off the bike while riding.
« Reply #10 on: June 21, 2010, 05:40:56 PM »
Stator covers?
...Keep dirt, water, and debris out of the alternator.  (Isn't that obvious?)
Also carries the Honda LOGO to advertise the Brand.
