Author Topic: Resurrecting an '82 CM450E  (Read 2885 times)
techsaavy
« on: June 21, 2010, 06:40:33 PM »
Hello,
I recently traded for an 82 CM450. It had been sitting for about 3 years with a broken accelerator cable. The guy had a new cable so that was a quick fix. This is my first bike. I've worked on cars since I was 12 (dad owns a mechanic shop), but this is the first bike I've worked on too. It was obvious the carbs needed a good cleaning because it wouldn't idle without the choke pulled out halfway and didn't have enough power to ride in overdrive. I took it to a small shop around here, where it sat for three weeks and he never touched it. I finally got frustrated and went and got it and decided to try to clean them myself. This went fairly well, as the bike had good power above 3/8 throttle (it was like it picked up another half of an engine!), but at idle it backfired through the carbs and would spit and sputter up to 3/8 throttle (lean problem?) I assumed it had something to do with the air needle, but on one carb it had seized in the body and the adjustment head broke off flush with the carb body. At any rate I rode it around like this for a couple of days and the stalling aside it ran well.
I ended up ordering a full kit off ebay that came with all the jets, needles, air cutoff valves, etc. I did note that the one pair of jets were the 115 size, the ones that the Clymer manual called for were 112. At any rate I tried to install everything that came in the kit (including float valve seats). This was obviously a huge mistake as when I was pressing the new float seats in it cracked the carb. So I figured I was up Schitt's creek. I ended up finding a motorcycle guy close by that had a pair of carb bodies (VB22's, same as what I had except a different letter after the 22) so I bought them and moved all the new parts over and put everything together. Everything was identical except the jet underneath the rubber plug. The bike will idle, but when you give it throttle it shuts off. If you twist the throttle really quick, it will lope, spit and sputter but never pick up. Air and gas blow back out through the carbs. I though maybe the jets were too large, so I replaced all the original parts, same problem.
I cleaned all the parts in an ultrasonic cleaner, checked all the vacuum ports and jets for blockage, but I notice when you open the throttle the vacuum pistons don't move. I reached in with a plastic bar and pushed up on one of the pistons while opening the throttle, and the thing never missed a beat. Also, if you shut off the fuel, as the carbs run it out, it will pick up like it should.
I don't know what should be my next step here? Can anyone please shed some light on my ignorance of motorcycles and CV carbs and help me figure out what I should be looking into? Thanks so much in advance!
-Lloyd G
OOO And Pron!
« Last Edit: June 21, 2010, 06:57:58 PM by techsaavy »
Offline Alan F.
Re: Resurrecting an '82 CM450E
« Reply #1 on: June 21, 2010, 08:35:34 PM »
Are you running it with the airbox attached?
techsaavy
« Reply #2 on: June 21, 2010, 08:39:30 PM »
For the last three days no, but I thought that might have had something to do with so I hooked it all up today and still the same result. The boots going into the airbox do have some cracks, but they're underneath where the clamps are, and these were there when I ran after cleaning the carbs but before installing the new kit/carbs.
KowalskiCraig
« Reply #3 on: June 22, 2010, 06:34:01 AM »
Hey I dont have an answer for you but if you look at my (Accelorator Pump) post I have an 81 CM400E Im sorta having some of the same symptons...maybe you can take some of the info these guys are giving me and try it and jump in on the convo.
Offline blue240sx
« Reply #4 on: July 17, 2010, 12:57:55 PM »
had a cm400 that would only idle on one cylinder and only really run well at high rpm.  same thing very very lean at anything under 5000rpm, if you tape off most of the intake area it would pick up, and as the thing came up on rpm it would just completely change character, as you said, felt almost like it added another cylinder
ended up having to dig the idle air bleed out of the carburetor housing (its pressed in) and i bumped the low speed jet size from a 72 to an 80
79 CB650
81 CM400C that will only run both cylinders at WOT
