Author Topic: Single Neutral Light, where to buy?  (Read 755 times)
razorsedge
« on: June 22, 2010, 03:14:11 pm »
Looking for a single Neutral light to install into my headlight housing. Anyone know where I can get one of these? Sounds like it should be easy but have been unable to source one.
I tried a couple cheap ones from Radio Shack but they just blow my fuse.
Some of the others I see on line are really long,
Maybe something like the HI Beam indicator in my wife's CL350?
This is for my 78 750F Supersport, Mini Gauges and Indicator Cluster removed.
Thanks,
« Last Edit: June 22, 2010, 03:26:45 pm by razorsedge »
Offline dusterdude
Re: Single Neutral Light, where to buy?
« Reply #1 on: June 22, 2010, 04:26:23 pm »
any major auto parts store will have it,also radio shack will too
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline the architect
« Reply #2 on: June 23, 2010, 08:00:46 am »
If you google "panel mount lights" you'll get more results than you need.  As mentioned above, locally, autoparts stores are a good place to start.  You can check electronics parts houses, too.
Rider no. 83 on the 2013 SOHC/4 Honda World Tour
Rider no. 228 on the 2012 SOHC/4 Honda World Tour
Rider no. 70 on the 2011 SOHC/4 Honda World Tour
my '75 CB750 cafe build photo documentary:  looking for the Lone Stars is like playing Where's Waldo -- enjoy.
http://www.flickr.com/photos/34828040@N05/sets/72157615892537535/
CB350 twin, rigid meat grinder:
http://www.flickr.com/photos/34828040@N05/sets/72157627005176764/
Blip Workshop
http://www.blipworkshop.com
http://www.facebook.com/blipworkshop
Offline Johnie
« Reply #3 on: June 23, 2010, 08:56:33 am »
Got mine at Autozone.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
razorsedge
« Reply #4 on: July 01, 2010, 12:23:06 pm »
Thanks, the one I got from AutoZone looks good. The Light ended up not being the short. It ended up being the Brake Lever Switch. Looks like the PO replaced the wires with speaker wire using plumbing solider. Once I cleaned it up and soldiered the correct wires with electrical solider, magically the problem disappeared.
