SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
Other Bikes
Topic:
checking valves on goldwing.....
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: checking valves on goldwing..... (Read 1459 times)
weltzing
Enthusiast
on:
June 23, 2010, 11:47:22 AM »
what is the easiest and best way to check the valve clearences?? im not getting fuel into the 3 cylinder after cleaning the carbs, so im guessing its not the carb, possibly the valve is sticking and not seating correctly.
Logged
kirkn
Expert
Re: checking valves on goldwing.....
Reply #1 on:
June 23, 2010, 12:05:18 PM »
What year / model?
For the 1000/1100's, pull the valve cover and check for clearance. Straightforward screw/lock nut adjustments.
Not sure for the 1200/1500/1800's.
Logged
weltzing
Enthusiast
Reply #2 on:
June 23, 2010, 02:41:15 PM »
yup sorry its a gl 1000 i know just pull the cover but do you like roll it over and get the valve up then measure or what?
Logged
weltzing
Enthusiast
Reply #3 on:
June 23, 2010, 02:41:56 PM »
i mean get the valve open then measure where?
Logged
mgbgt89
Hot Shot
Reply #4 on:
June 23, 2010, 03:38:32 PM »
No.. you check valve clearances when they are closed.
Here is a good how to with pictures.
http://www.salocal.com/goldwing/valve_adj/gl1000_valve.htm
Last Edit: June 23, 2010, 03:40:26 PM by mgbgt89
Logged
78 k550
Master
Reply #5 on:
June 23, 2010, 08:37:18 PM »
I can scan you the page in the manual.
Im not getting a hot pipe on #4.
I have a 75 and 84.
Paul
Logged
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Other Bikes
Topic:
