These vent hoses attach to the bowl overflow tubes with clips, routing down from the carbs between the engine and swingarm. These two particular hoses don't actually reach the bale that hold the O.F. tubes, at least in the applications I've seen; they actually stop a few inches short of the bale, or just below the swingarm.
The white clip actually belongs above the black clip; see above pic, lower left corner, where you can see the clip located correctly.
One thing... this is a "K" frame. I don't know how different things are for the "F"s; I believe they have an extra couple of vent hoses on each end as described above. At least this will get you into the ballpark with these particular hoses.
