Author Topic: Need help, please  (Read 4241 times)
traveler
Re: Need help, please
« Reply #25 on: June 28, 2010, 04:26:34 PM »
but the tip of my needle is rubber!
~Joe
Offline cameron
« Reply #26 on: June 28, 2010, 04:39:57 PM »
OK..
So it DOESn'T leak when you manually move the float.
It DOES leak when the bowls are ON,..
It must be the float.
Maybe the float is rubbing against the BOWL? So it is frozen with the bowl on?
1976 CB550F
traveler
« Reply #27 on: June 28, 2010, 06:37:21 PM »
when I had the bowl off yesterday, and then put it back on....I moved the carb back and forth, and could hear the float moving in there.
~Joe
Offline cameron
« Reply #28 on: June 28, 2010, 07:08:46 PM »
Hmm.
Well, lets postulate that the Float is floating.
THEN, the only thing that can possibly be preventing gas shut-off is the valve, right?
If the float is good, the valve must be either bad or sitting wrong.
Have you tried switching that valve to a different carb? (maybe the float, too, just in case?) That seems like a good idea.
Luckily, I heard that if your carb leaks enough gas into your engine, the whole thing can actually explode while you are riding. :)
1976 CB550F
traveler
« Reply #29 on: June 28, 2010, 07:27:01 PM »
It's not leaking THAT much fuel....it is running a tad bit richer than the other cylinders.
~Joe
Offline Kframe
  • Life is good!
« Reply #30 on: June 28, 2010, 11:27:17 PM »
Just tossing this out there (don't even know if this would cause the problem) but... is the float being installed upside-down?
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline droopy
« Reply #31 on: June 28, 2010, 11:41:13 PM »
had a float that was slightly twisted on one side would move fine butt with fuel would catch on float bowl  ??? look at float several times before i saw it
2007 lifan 200cc sport ohc thumper
traveler
« Reply #32 on: June 29, 2010, 04:27:56 AM »
i'll check it again...thanks.
« Reply #33 on: June 29, 2010, 06:47:00 AM »
I still think its a faulty float valve....or the spring inside it.
yeah your float is good, but the pressure it imparts on the valve is much less than your finger.
i'd say you have an original float valve with a worn out spring, or you rebuilt your carbs and the new valve is not seating properly with the pressure your float applies as the gas rises...
am i way off base?
Offline Flying J
« Reply #34 on: June 29, 2010, 10:40:51 AM »
am i way off base?
Im with ya on that one. I would change the needles around and see if the problem stayed or moved.
