SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Internal engine case coating?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Internal engine case coating? (Read 947 times)
millerza
Zach Miller
Enthusiast
750K8 fixing rebuild probs
on:
June 28, 2010, 05:22:16 am »
So I was stripping the cases with methylene chlroride and a little got on the coating inside. I didnt think this was a big deal, but I was curious about the coating. I had thought this coating was just like a stain caused by oil/heat? It came off like paint. So whats the deal with this stuff? Its purpose? Can someone affirm that some coming off from stripping doesnt matter. Will it peel more from this spot.
Logged
Bodi
Really Old Timer ...
Re: Internal engine case coating?
Reply #1 on:
June 28, 2010, 01:49:24 pm »
In my experience there is no paint like coating on the inside of the cases. Obviously some PO could have done that though. I have seen old engines with a varnish/glue coating on the insides from decades of running with rare oil changes. It can peel off in sheets.
Logged
Nikkisixx
Expert
Reply #2 on:
June 29, 2010, 06:33:50 am »
I'm with Bodi. I've never heard of any coating used in old Honda cases, but is is possible. More likely it is paraffin or some other gunk out of the oil or perhaps an additive like slick 50 or STP stop leak. You will want to get it out of there if it can flake off and do bad things.
Logged
millerza
Zach Miller
Enthusiast
Reply #3 on:
June 30, 2010, 07:29:46 am »
ok heres a pic. Im talking about the goldish stuff on the alum pieces.
So is this a stain? Would anyone see a need to remove this.
Ive washed and scrubed it so its clean, but this stuff stays like a coating.
Last Edit: June 30, 2010, 07:32:46 am by millerza
Logged
wannabridin
Patience made me a
Master
-Garrett
Reply #4 on:
June 30, 2010, 09:48:03 am »
that's an oil stain from heated oil and somewhat porous aluminum. years of hot oil sloshing around the cases will stain them. as for getting it off, i'm not 100%, you'd have to let some of the guys w/ more experience chime in
Logged
Lavis500
Why don't you go ask a
Hot Shot
"Don't plan vast projects with half-vast ideas"
Reply #5 on:
June 30, 2010, 10:02:24 am »
I don't have terribly much experience myself, but I can tell you that I cleaned a very similar oil stain from the pan of my 500 with a sonicare toothbrush (or a sonicscrubber if you wish, since they are much cheaper) and some kerosene. It went from brown to shiny, new-looking aluminum! I'm sure that any amount of elbow grease with any scrubbing device would work. Kerosene was recommended in my shop manual for cleaning engine parts, and it seems to do a good job. As for whether or not you NEED to clean it - I don' know. My guess would be that a clean engine is a happy engine, reduce carbon buildup to reduce friction and yadda yadda blah blah. I don't think removing it would hurt, that's for sure.
Logged
"Whatever it is, I swear I didn't do it!"
'73 CB500 - Sally
millerza
Zach Miller
Enthusiast
Reply #6 on:
June 30, 2010, 12:06:56 pm »
Ok Im going to remove it. The methylene chloride I oversprayed seemed to remove it pretty well.
THANKS GUYS
Logged
SKTP
Master
Reply #7 on:
June 30, 2010, 12:12:16 pm »
You are so lucky...my entire engine is Dirt on top of black grime on top of burnt gold...every part! good times.....
Logged
1978k rebuild thread
http://forums.sohc4.net/index.php?topic=68423.0
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Retro Rocket
Eggs are hard due too a
ROCK & ROLL
Reply #8 on:
June 30, 2010, 04:28:18 pm »
I would probably keep any solvents from touching the bearing surfaces just to er on the side of caution, don't want to damage them..
Logged
750 K2 1000cc
ekpent
To many bikes-but lookin' for more
Reply #9 on:
June 30, 2010, 04:39:29 pm »
I wouldn't worry about the color just worry that there is no grime or grit and do not introduce any,keep those oil passages,bearings, nice and clear. Color is just some patina,call it a pre-treat,as it will just come back again someday.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
