Author Topic: CB650 turn signals  (Read 2580 times)
1979CB650_Chris
CB650 turn signals
« on: February 10, 2006, 11:15:21 PM »
Hey all,
I have a fairly easy question.  The PO of my motorcycle put aftermarket turn signals on and ran the wires but did not hook them up.  I am currently in the process of wiring the signals up and i as wondering if the key is in ON, do the turn signals light up like the parking lights on a car.  Or are they dead until the turn signals are activated?  Thanks
WiredForStereo
Re: CB650 turn signals
« Reply #1 on: February 11, 2006, 04:07:04 AM »
The entire bike is dead until you turn the key on.
There are no running lighs w/ the turn signals in the rear, and mine doesnt have them in the front either, just the turn.
Sol
Offline cb650
« Reply #2 on: February 11, 2006, 07:58:57 AM »
The 650 should have running lites in the front.
                     Terry
WiredForStereo
« Reply #3 on: February 11, 2006, 10:35:45 AM »
Someone put on cheap aftermarket ones, so........
Offline rab1dwolf
« Reply #4 on: February 11, 2006, 10:45:04 AM »
the fronts double as running lights.
I'm in the process of replacing mine as well and from what I've seen theres usually a third wire to make them function as running lights.  They should at least blink when the signal is turned on though.
I'm thinking about taking a look into making the running lights a seperate light fixture then the turn signals.
1982 cb650sc nighthawk.  the work never stops.
Offline mrbreeze
  • Not your average
« Reply #5 on: February 11, 2006, 11:27:36 AM »
You don't want running lights in the rear .You want them up front. If the lights mount the same,switch the fronts to the rear, IE... 3 wire  lights in front, 2 wire in rear. Wires should be 1. Ground , 2.Hot with key on (Running light), and 3. Hot with signal on (Turn light). Check the wires coming out of the bike with a test light to make sure they are wired right.
MEMBER # 257
Offline cb650
« Reply #6 on: February 11, 2006, 05:52:09 PM »
I have a set of stock 79 signals if you want.  Got them in a basket case.
                      Terry
