Author Topic: Trying to start for the first time since ripping apart..no luck  (Read 1676 times)
Offline Scott S
Re: Trying to start for the first time since ripping apart..no luck
« Reply #25 on: June 30, 2010, 12:49:26 pm »
 Look on the side of your carbs. You should see a small screw on each one (I'm sure someone here has a pic). Gently bottom them out, then back them out 1.5 turns for a good starting point.
 I guess it's safe to assume you haven't synched the carbs? How hard would it be for you  to take them off so you can at least bench synch them?
 You may need full choke at first, then less as the engine warms up.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
redbullssg
« Reply #26 on: June 30, 2010, 12:56:52 pm »
Here is a simplified wiring diagram copied from a link on this forum....
Offline Zaipai
    • My Home page
« Reply #27 on: June 30, 2010, 06:00:08 pm »
Here are two images, hope they help..
(click image for larger version)
.: Scott :.
Its my Avatar..
75 CB550F  |
Offline robdrobd
  • Who? Me?
  • Isn't she a beauty?
« Reply #28 on: June 30, 2010, 06:07:11 pm »
Great, I should probably get some air filters and a muffler on before going on. Also, it now starts right up, but doesn't fire on pipes 1 and 3. Plug wires are not switched. Any ideas, or should I get the air filters and muffler on first?
Offline cb750-bobber
  • With age, comes character...I support vintage!
« Reply #29 on: June 30, 2010, 06:24:17 pm »
Yeah, I wouldnt run it with no head pipes, you will cause uneccessary abuse to your engine...Get an exhaust on there and try firing her up again before adjusting anything else.
