Author Topic: Ceased Master Cylinder Piston  (Read 1284 times)
Offline Simpson
  • I ain't no
  • Aged to perfection
« on: July 01, 2010, 08:57:19 am »
Hey Folks
I've got a master cylinder I'd like to rebuild but the piston is ceased all the way down.
Standard 70's black anodized of the CBs.
How can I pop it back out without destroying the housing?
1970 CB750 K0
1975 CL/CB 360 Mix
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
Re: Ceased Master Cylinder Piston
« Reply #1 on: July 01, 2010, 09:03:31 am »
I used compressed air and blew it fifty feet across the driveway so be careful.
Offline lofton05
  • 76 CB750F
« Reply #2 on: July 01, 2010, 10:04:02 am »
Same here,  nearly took out car windshield.  :o
Offline camelman
  • Man... Myth... Legend
« Reply #3 on: July 01, 2010, 10:11:11 am »
I'd be careful with compressed air in those things.  Once the resistance force is removed, the air will still be applying force, essentially setting up a small weapon.  If you go with an incompressible fluid (such as brake fluid), then the whole thing is a little safer.  When I remove brake pads, I unbolt the caliper from the pivot arm, and then squeeze the brake handle until the pad comes out.  You generate much more pressure that way than with typical compressed air, so it is bound to move.
Is that the piston you were talking about though?  I thought you mentioned the master cylinder (on the handlebars).  If you are rebuilding the whole thing anyway, then just shove it out with a screwdriver.  Be careful about scratching any surfaces inside though.  Some PB Blaster will help too.
Camelman
1972 350f rider: sold
1972 350f/466f cafe: for sale
1977 CB400f cafe:sold
1975 CB400f rider: sold
Offline Simpson
  • I ain't no
« Reply #4 on: July 01, 2010, 11:31:33 am »
Well not even the power of 100 psi air got it out. Had to take a screw driver and force it out by the lip, piston push side.
Here's why, see picture.
1970 CB750 K0
1975 CL/CB 360 Mix
Offline mycb750k6
  • Rocketman
« Reply #5 on: July 01, 2010, 12:14:27 pm »
You might want to consider running a 12mm flex-hone through it before rebuilding it. Looks pretty nasty.
Offline Simpson
  • I ain't no
« Reply #6 on: July 01, 2010, 01:02:34 pm »
Good idea! Now to go blow more money on ebay for a rebuild kit.  ;D
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Simpson
  • I ain't no
« Reply #7 on: July 01, 2010, 01:06:10 pm »
Anybody know where to get a NOS kit?
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Gordon
  • 750K1, 550K2
« Reply #8 on: July 01, 2010, 01:09:52 pm »
Honda
Offline mycb750k6
  • Rocketman
« Reply #9 on: July 01, 2010, 01:50:00 pm »
Yes get a Honda kit please. Otherwise it may not work to your liking.
Offline Simpson
  • I ain't no
« Reply #10 on: July 01, 2010, 02:01:44 pm »
The after markets don't seem to work well.
Honda Kit on ebay is 48 shipped.
Guess jump on that...
1970 CB750 K0
1975 CL/CB 360 Mix
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: July 01, 2010, 02:15:40 pm »
Call your local Honda dealer with the part number.  They can probably get it for less, and you don't have to pay for shipping.
