Author Topic: Reading the Manual - jet size notation  (Read 794 times)
Offline ron.cieri.313
« on: July 01, 2010, 01:09:54 pm »
Hi all, I am going back to a stock air box on my '76 CB750K.  I think they had #105's on it prior to my rejetting to compensate for the &()&**&&%^%&^%(^&(*(_^^%$$%^ air pods ;)
found this notation in the manual but don't understand it
Main jet    #120 (#105, K3)
....does that mean stock main jet size is #120's unless i have a K3?...which I don't
thx!...ron
Making the world a better place, one motorcycle at a time.
Offline laser145
  • underfunded
Re: Reading the Manual - jet size notation
« Reply #1 on: July 01, 2010, 01:11:52 pm »
I don't know the answer...but I also have a K6 and am doing the same thing...so I'm interested in the answer
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: July 01, 2010, 01:20:16 pm »
K6 should be a 105.
Offline 333
  • Time for change
« Reply #3 on: July 01, 2010, 01:24:25 pm »
Parts diagram says #105
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
« Reply #4 on: July 02, 2010, 05:56:45 am »
If your running the 4-2 exhaust I saw pictured early on I would probably shoot for the 110 main,or have some available for comparison.
Offline laser145
  • underfunded
« Reply #5 on: July 02, 2010, 06:43:12 am »
So if I'm running a MAC 4-1...still 105 Main Jet?
Cheers
Offline Doctor_D
« Reply #6 on: July 02, 2010, 08:03:33 am »
Depends.
How's it running? What do the plugs look like? Do you have good power across the range of throttle openings?
Take care,
David
1978 CX500
1971 Norton Commando
Offline Gears
« Reply #7 on: July 02, 2010, 09:47:29 am »
I'm interested in this too. I'm rebuilding a set of carbs off a K5.
My manual lists the mains as being 120's(in the main section. It didn't mention anything about jet sizes in the K5 supplement elsection) but the keyster rebuild kit I purchased came with 110's.  And the main jets I pulled weren't very well marked.  I can make out a 1, then there's a space, a 5 and a little k/star symbol. I've been working under the assumption that these are either 105 or 115's.
So you can see I'm a bit confused by all this too.
Not to mention trying figure out what I should run if I go with pods and Carpy's 4-1 exhaust .
Offline xenoscr
  • 1975 Honda CB750 K5
« Reply #8 on: July 02, 2010, 10:21:21 am »
I have a 1975 CB750K5. I've just gone back to the stock airbox from pods. I had #42 idle, one noch lower on the needle, and 115 mains. The link in the FAQ list the following:
Code: [Select]
Year    Model  Casting #    Type Float Main Slow JN Screw
69-76 CB750K B750A & 7A   1    26    120  40 3  1
               657A         1    26    110  40   4  1
               657B & 086A  1    26    105  40   4  1
Source: http://www.motorcycleproject.com/motorcycle/text/specs.html
So now I have #40 idle, notch 4, and stuck with the 115s since I went with a K&N filter. I first tried the jetting I had for the pods. Way to rich, black smoke and everything out the tailpipes, damn.... had to rejet. Runs fine. It was past my bedtime when I finished rejetting to stock so I've yet to do a plug chop. I'm not getting black smoke from though... so I'm at least not super rich.
XeNoSCR
« Last Edit: July 02, 2010, 10:26:52 am by xenoscr »
1975 Honda CB750 K5
