Author Topic: Cb550 Jets...  (Read 1602 times)
Offline Hootis29
    • Hootis Motor Sports
Cb550 Jets...
« on: July 01, 2010, 08:29:24 PM »
I have a cb 550 with pods, and a 4-1 pipe. They carbs were re-built to stock, and I need to run the bike half choke.
I think I needed bigger mains (right?), but where does a guy find them?
Thanks
Paul " Hootis" Noskowiak
1975 CB 750
1975 CB 550 (Cafe Project)
1973 CL 350
1972 450
2006 Buell Ulyesses
2001 Buell Blast (Custom)
1977 Triumph Bonne
1975 XL1000
1972  750 Commando
Assorted other CB's mostly 500, 550's
Offline Doctor_D
Re: Cb550 Jets...
« Reply #1 on: July 01, 2010, 10:31:46 PM »
Do a search on carb tuning. There's lots here.
But, to answer your question, maybe and maybe not.  The mains barely effect low-throttle cruise. That's in the needle, needle jet, and slide cutaway range. Lower the needle clip one position (thereby raising the needle and enriching the 1/3-1/2 throttle mixture) and see how it goes first.
Take care,
David
1978 CX500
1971 Norton Commando
Offline Kemp
Re: Cb550 Jets...
« Reply #2 on: July 23, 2010, 12:06:31 AM »
Just jetting my 76 CB550F cafe project also. I've been adding to the PODS thread in FAQ. Basically I'm almost back to stock settings with a slightly richer main (#100) and needles raised 1 notch (#3) richer. My plugs are sooty and absolute black but it actually runs quite well. I will return the needle to stock position and see how it runs then. All other facets that affect the carburation have been checked so the engine is fully tuned/set up to avoid issues that could affect carb jetting.
Main #100
pilot #38
Needle - 3rd notch
Pods - unifilters
Plugs - NGK DR8ES
