Author Topic: Project LINT - A humble beginning.  (Read 1253 times)
Offline dfekt13
    • My Site
« on: July 02, 2010, 12:21:34 PM »
So I recently purchased a 1973 CB500K from a guy locally. I have been wanting to build a bike for a while, and I definitely wanted to go with a Honda4 for my first bike regardless of if it was stock or custom. Although there's been problems along the way I do think I lucked out on the bike, it has all the important features I planned on. When I first saw it I knew, while she would need plenty of love, she was just the right #$%* to build from. Someone had put in a good amount of work back in the day and she was already hard tailed and raked and had a lot of the big work already done. And they had don it well too. You can tell she was hard tailed and chopped back in the day, I removed probably 30 pounds of bondo where the sporty tank was molded on and the frame was all molded up too. I stripped her all the way down and had the frame off to my good friend Steel Steve Stinson for some TLC to tighten up the welds and make sure she's roadworthy. He also worked on some other bits for me, fitting the fender from an old Triumph, and donating and fitting the new tank. We actually haven't made the final decision on the tank, it will either be a King Sporty sitting up nice and high or a small peanut mounted the same way, still deciding. My boy Heath Brogan tore into the carbs and found some trouble, so we are waiting to get a decent set from one of the members here just as soon as my paycheck comes through. The engine seems to be in decent condition so we're gonna leave her be for now and see how she runs when we get to that point. Hopefully she'll be good enough to get me through this season and then I plan to have her rebuilt over the winter. Lets see, aside from that I'm adding a mini coil-over seat suspension, got a super nice seat pan donated by my boy Milton, he donated the fender and some other bit too. This bike is all about getting a brother on the road on his first custom machine and I can't thank the people enough that have lent a hand or donated parts. I took some black clubman bars, flipped em upside down and mounted them on four inch dogbones. Headlight being used is a ebay find that I sprayed black. Got a wind turbine 3-phase Rectifier that is super nice for 15 bones on the ebay. Going with the old Fork pickup regulator. Would love to run her Kick-only but magnetos cost a bunch so I'll probably just run a small battery and kick her anyway. That's all for now I gues. I'm attaching some pics from the day I got her and a couple of mock up shots. Get the frame back Monday so there will lots more pics to come as progress allows. Stay tuned.
Dancin' Rik
« Last Edit: July 02, 2010, 12:51:25 PM by dfekt13 »
d*Fekt
'74 CB550 in a rigid '73 cb500 frame
Offline dfekt13
    • My Site
Re: Project LINT - A humble beginning.
« Reply #1 on: July 03, 2010, 11:45:33 AM »
And it keeps getting better. Today my boy Steve called to let me know just how bad the neck job was butchered. Way back whenever, someone decided to rake her out. They made a crude, jagged cut behind the neck, pulled her out where they wanted it, and then wrapped 1/4 inch plate around the neck and welded it on. Now we have the plate peeled off and it's a mess. He's gonna try to get it worked out but I def wont be getting the frame back on Monday. DANG!!
d*Fekt
Offline Ecosse
  • Member #4139
    • My 550 walk around video
« Reply #2 on: July 03, 2010, 01:51:37 PM »
glad to see one come back from the dead.
kudos for taking the initiative.  8)
1974 CB550K
                                  Your 1%er name
Offline dfekt13
    • My Site
« Reply #3 on: July 03, 2010, 06:04:29 PM »
Thanks Ecosse.
I can't wait to get this thing out on the road.
Still trying to get suggestions for ignition coils. Posted in the sohc forum, looking for a 5 ohm points type coil. Anyone got any ideas, just looking for something I can pick up at the junk yard and strap on the rat.
d*Fekt
Offline Ecosse
  • Member #4139
« Reply #4 on: July 03, 2010, 06:25:20 PM »
keep searching in the faq and in the tech pages as well as the forum. i can't recall specifics but there are other coils one can use.
scratching my head at the moment... wanna say the '80's cb 900 and such?
1974 CB550K
                                  Your 1%er name
Offline dfekt13
    • My Site
« Reply #5 on: July 03, 2010, 10:03:29 PM »
Thanks ill look into those
d*Fekt
