Author Topic: removing electrical tape residue from rubber parts  (Read 4665 times)
Offline gmonkey
« on: July 02, 2010, 10:28:22 PM »
One of the rubber pieces that connect the air box to the carbs cracked up so the PO wrapped electrical tape around it.  I don't think the electrical tape is really doing the trick since the crack is in a corner where the tape is likely to not reach very well so I want to replace it with liquid electrical tape which has served me pretty well in the past.  But now the rubber piece has the electrical tape glue all over it and I want to get it clean before I patch up the holes.  What would break down the glue without damaging the rubber?  I saw GooGone, rubbing alcohol and WD40 but I don't know how these things affect rubber.  Something I can just leave it soaking in for a few hours?
Big pile of 76 CB550F parts
'98 FZR600 purring like a chain-smoking kitten!
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: removing electrical tape residue from rubber parts
« Reply #1 on: July 02, 2010, 11:59:38 PM »
Not that I can be certain, but I reckon you'll be close to the money using WD40. Another option might be 'Zoff' Universal Adhesive Remover.
Chemists (pharmacies) sell it here. It's for the removal of adhesive from plasters like you'd use for first aid. It's okay for human skin so I reckon it should be safe enough for rubber?  ???
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Alan F.
« Reply #2 on: July 03, 2010, 07:47:35 AM »
Just squirt some WD40 on a clean shop rag and wipe the adhesive off with that. WD40 is VERY friendly to rubber and plastic parts, you have nothing to worry about, I wouldn't bother soaking the part.
Using liquid electrical tape I'd be very careful to be sure the stuff is well cured before you run the engine, the suction through the carb boot may be strong enough to suck some of it into your engine.....and that would probably be a bad thing, right?
-Alan
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #3 on: July 03, 2010, 12:31:47 PM »
-Alan
WD40 works great. Also good for getting tape goo off of wiring harnesses.
Fonda Honda
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: July 06, 2010, 09:48:25 AM »
Goo Gone will remove the adhesive residue no problems.  No real soaking required, spritz it on, let is sit a couple of minutes, then wipe if off with a terrycloth rag that has more Goo Gone on it.  Paper towels don't work as well, the fuzzies on the terrycloth make it workd pretty well.
mystic_1
- John Augustus Shedd
Offline grumpy
  • ..... '73 750K3 .....
« Reply #5 on: July 06, 2010, 12:54:02 PM »
naptha & a rag takes off most adhesives and also works very well on chain lube spatters and tar balls from the road.
