Author Topic: gas tank  (Read 927 times)
Offline rchrdms
  • Honda CL350 Twin '72
    • Richard F Meese
gas tank
« on: July 04, 2010, 06:26:42 AM »
My '72 350 twin has, I think, water in the fuel. There is a white gunge all over the float bowl and carb parts. I even noticed some liquid beading on the floats. I think I used a gas container that was contaminated with water to refill the tank after rebuilding the carbs. My question is: How do I clean this up? I've cleaned the carbs again and removed the white stuff. What about the tank? Is there anything to do to get rid of the water? Thanks.
Offline Old Scrambler
Re: gas tank
« Reply #1 on: July 08, 2010, 11:51:20 AM »
Undo the fuel lines and drain a cup or so..........the water will be the first to flow.........also drain the petcock and the bowls..........modern fuel has 10% ethanol which degrades to a small amount of water content if you let it sit in a tank or can for a few months.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
