Author Topic: SoCal Mut-N-Chop CB750 - ITS DONE!!!!  (Read 81074 times)
Offline tbarnhart
Re: SoCal Mut-N-Chop CB750 Cafe - Custom Foot Pegs???
« Reply #150 on: July 25, 2011, 03:56:58 PM »
I really love the tank.  Its got a great look to it thats for sure!
Offline brycegp
    • 1971 CB750 "Mut-N-Chop" Cafe Project
Re: SoCal Mut-N-Chop CB750 Cafe - headlight bucket finished!
« Reply #151 on: July 30, 2011, 10:51:45 PM »
So after a long hiatus I am finally back in the groove working on my project.  I'm on the home stretch...and hopefully after this final push...it WILL be done.
So i finished fabbing all the light holes and what not to my headlight bucket.  I put in all the lights, switches, speedo, and headlight to make sure everything fit...and its looks pretty badass.   Now its in the box of #$%* to get body work and paint...
1971 CB750K/F - El Toro
El Toro Build Thread - http://forums.sohc4.net/index.php?topic=73552.0
Offline Dyrden
Re: SoCal Mut-N-Chop CB750 Cafe - A little progress...
« Reply #152 on: July 31, 2011, 07:43:04 AM »
That looks sweet.  Perfect proportions on the headlight.  Im still on the hunt for one shaped like yours.
Offline unitedguitar
« Reply #153 on: July 31, 2011, 03:17:10 PM »
I used bicycle pegs for mine. They don't fold up anymore because of how I mounted them but they look pretty slick. I just removed the stock ones and rigged up a bolt that was held in place by the stock retainer pin. I had to cut a small groove in the bolt and flatten out one side of the pin to make it work but they are strong and can withstand over 250 pounds of weight on them.
They do look good!
Got any pics of the hardware you fabbed...before you mounted them up...just to see exactly what you mean?
I don't have any pics of how it all fits together but if you are really interested I can get some or draw a picture or something.
Ben Whitener
Offline KTwo
Re: SoCal Mut-N-Chop CB750 Cafe - Oil Tank Finish - POLL
« Reply #154 on: August 01, 2011, 05:00:11 AM »
Where did you get the hose supplies?
X2!!  also, VERY nice work!  looks a lot better than i thought!
The oil line supplies came from a little mom & pop hardware store in Burbank, CA.  $9/ft for braided oil line...and the fitting were cheap too.  I had to strip the blue/red anodizing...but whatever.
This little store is pretty amazing.  Its a "find anything you need" spot for the mad scientist.
Guessing here, Berg hardware? :)
Just read through this, nice build.
'02 919
'72 CB750 (project)
'74 CB200T
'79 XS650
Offline brandEn
« Reply #155 on: August 04, 2011, 10:12:29 PM »
This project is sweet. Just found it. Where did you get those indicator lights that you installed in the bucket?
Offline lucky
« Reply #156 on: August 10, 2011, 06:27:03 PM »
I liked the oil tank that you made.
I am building my own oil system and need to know which hose, from the engine, is oil going TO the tank, and which is oil going BACK to the engine.
Would you help me? Thanks
luky@sonic.net
It does not show anything in the shop manual.
Offline brycegp
« Reply #157 on: August 10, 2011, 10:33:10 PM »
The indicator lighst for the headlight bucket came from ebay...
Offline brycegp
« Reply #158 on: August 10, 2011, 10:35:59 PM »
luky@sonic.net
To tell you the truth i really don't know which is the feed and which is the return...sorry...
Offline brycegp
Re: SoCal Mut-N-Chop CB750 Cafe - 1 step backwards!!
« Reply #159 on: August 11, 2011, 11:46:40 AM »
I can't even explain how F*&$#ing livid I am right now.  I was installing my new shocks on the back of my bike and I see this...WTF?!?!?!?!
I have NO IDEA how it happened, when it happened, or whose ass to kick because it happened.
I called coker and they say it isn't a factory defect.  For a second I thought it might be a tear or split.  After time of being under pressure of inflation, it split or something.  But they say not the case.
Whatever...I have no idea.  racking my brain trying to come up with anything that might be what happened...  "did I get the angle grinder anywhere near my bike??"  HAHA...Im not crazy!!  "Did I get my soldering iron any where near it??"  Well...I was soldering connections on my wiring harness the other day..but I'd have seen something like THIS go down!!
Anyway...I'm just venting...so pissed off...
Offline brandEn
Re: SoCal Mut-N-Chop CB750 Cafe - One step backwards
« Reply #160 on: August 11, 2011, 03:09:09 PM »
Dude that sucks. That looks like a defect to me. Your iron would have residue on it if it did that.
Offline brycegp
SoCal Mut-N-Chop CB750 - Gettin down to the finishing touches...
« Reply #161 on: August 13, 2011, 12:52:33 PM »
So here are some of the final bits....
Velocity Stack screens...and almost had to sell a kidney for these...who knew!!??
New shocks...had to go with longer than stock due to the lengthened swing arm...
AND new cables...Motion Pro braided SS...purrrrty!!  Installed them all and its a sweet look...
Painted the oil tank to match the engine block and swing arm...
Scored a very nice headlight screen...
Finished the 4 into 2 exhaust headers with rolled end pencil tips...stuffed with a baffle and glass packing...
The gas tank and headlight bucket are going to the body shop for paint tomorrow.
Getting so close I can taste it...
« Last Edit: August 13, 2011, 01:24:05 PM by brycegp »
Offline brycegp
Re: SoCal Mut-N-Chop CB750 - Teaser...98% complete!
« Reply #162 on: August 17, 2011, 08:47:34 PM »
Just had to put it all together to see it before sending the headlight, gas tank, and oil tank out for paint...
Offline Dyrden
« Reply #163 on: August 17, 2011, 09:21:47 PM »
Cool photo effect.  It lends itself to your build.  The stance looks nice.  Im creeping up on getting a roller soon too.
Offline srbakker
  • Spam & Eggs
« Reply #164 on: August 17, 2011, 09:30:13 PM »
Looks fantastic!  I plan to steal all your ideas...
I don't know if you found knee pads yet, but Tech Spec sells uncut sheets for about $45 that you can cut to whatever you need.  I have a precut set on my Speed Triple and they are pretty high quality, if not exactly cheap.
Cheers!
1975 CB750 K5
2007 Triumph Tiger
2007 Triumph Speed Triple
1971 Kawasaki F7 175 Enduro
« Reply #165 on: August 17, 2011, 10:23:19 PM »
Bryce, i really like that you have managed to do something completely original without just dumping BCR stuff all over it then trying to sell it for 15 grand... ;)   One question though, with the smaller tank, is it a bit cramped to ride or is it all ok.?
Offline brycegp
« Reply #166 on: August 17, 2011, 10:27:59 PM »
Cheers!
I did find them...NOS...and I am charging $$$ for revealing the secret stash.  ;)   The guy is charging $150 a set.
Offline brycegp
« Reply #167 on: August 17, 2011, 10:31:51 PM »
WOW!! Thanks, RR!!  Coming from you...I really appreciate the compliment.
I appreciate all compliments, of course.  But you're one of the guys around here that's seen it all...so thank you!
As far as the ride-ability goes...I haven't had it on the street yet...  Looking forward to that day...and its very close!!
« Last Edit: August 17, 2011, 10:36:12 PM by brycegp »
Offline lucky
Re: SoCal Mut-N-Chop CB750 Cafe - Rebuilt carbs w/ Velocity stacks!!
« Reply #168 on: August 18, 2011, 11:31:18 PM »
Nice!! lotta cool ideas here, I'm likin that starter button especially.. :)
I do not think the starter button will work because it cannot carry the current unless it goes through a relay.
Offline brycegp
« Reply #169 on: August 19, 2011, 07:18:35 AM »
Its a 12V switch.  The current that goes thru it is not that great.  The starter button isn't feeding power directly to the starter.  The starter solenoid does that.  So the solenoid IS the relay.  The starter button merely feeds power to the solenoid's electromagnet.  The electromagnet acts as a "button" inside the solenoid thereby activating the solenoid and completing the circuit between the battery and the starter.
The big juice is going thru the 10 gauge wires going from the solenoid to the starter.  And the solenoid is drawing its power directly from the battery / charging system...NOT the starter button.
Besides I tested it...and cranked the motor already.  Works like a charm...
« Last Edit: October 16, 2011, 08:22:58 AM by brycegp »
Offline brycegp
« Reply #170 on: August 21, 2011, 11:06:25 AM »
to mark the completion of my bike, I got a new tattoo...
Offline brycegp
« Reply #171 on: August 26, 2011, 01:52:40 AM »
So I am going with non-honda emblems on the tank, I think.  I mean...its got Harley, Ducati, CEV and one-off parts.  Not to mention all the aftermarket cafe parts...so branding it "honda" isn't at all accurate.  but then again, its a honda frame and motor...is that all that really counts?
So any suggestions on tank emblems??
My brother came up with this one...cuz to him...well, it looks like a bull.
« Last Edit: August 26, 2011, 01:54:51 AM by brycegp »
Offline lucky
« Reply #172 on: August 26, 2011, 02:52:24 AM »
I was looking at that tire damage thinking it could be damage from mounting of the tire. Either a tire iron,screwdriver or installation machine.
Also I am wondering about that rear part of your frame where you had the steel plates welded on, that it might get in the way when the rear wheel travels up and down. You know,  the tire could hit the sheet metal?
Offline brycegp
« Reply #173 on: August 26, 2011, 07:26:04 AM »
yeah...that's why I lengthened the rear shocks...to add room for suspension travel.  In addition, I am going to add room another way if it bottoms out regularly.  I already have the idea on how add another 1".    ...I am just going to do it as a last resort...
Offline socalenduro
« Reply #174 on: August 26, 2011, 08:05:15 AM »
Did you test the length of the stroke for those new shocks? that tire looks REALLY close to the tail loop you welded in....
Would suck to put all that work and love in to find that every time you hit a bump your rear tire rubs
