Author Topic: no spark  (Read 1354 times)
cbcoker
no spark
« on: February 12, 2006, 08:57:15 PM »
My problem is as follows: My 73 CB350/400 has no spark and is not getting any electricity to the coils. I have since cleaned/adjusted the points, replaced the coil and wires and checked the fuse. The battery is fine and is engaging the starter. I have voltage at the points but no continuity from the points to the coils. I replaced the coils and wires because they were frail and a wire broke on me one day when messing around with the coils. I am using an older set of coils off of a Kaw and wires that are from a car. The wires have good continuity but the Kawi coils are a little shorter. The problem is that I am not sure if the coils were grounding out to the frame or not, it doesn't appear so on the schematic. Just in case thought I ran a wire around where the coils attach to the frame and then around another ground...still no spark. I had a problem with the kill switch not working but was able to remedy that and it is now functioning. It has continuity when it should and not when it shouldn't. I got the coils from my father who said they came off a running bike. The I am not sure what to do/where to turn at this point. I've never gotten the bike to run and it seems like I keep running into these kinds of walls. I don't have too much experience working on older bikes but I guess I am getting a crash course now... Please any advice you might have would certainly help...Thanks S
Offline Bodi
Re: no spark
« Reply #1 on: February 12, 2006, 09:21:02 PM »
Something isn't right.
The coils get +12V from the battery - through the ignition switch - and complete the circuit to ground through the points. If you have voltage at the points but not at the coils... well, it makes no sense.
The power (black) wire to the coils comes a long way through the harness, as the ignition and kill switch are involved. The coloured wires for the coils go pretty much directly to the points; the wires attached to the points plate connect directly to one end of each coloured wire, the other ends are beside the coils. There is NO ground connection to the frame at the coil. The iron core is grounded by being bolted to the frame but nothing electrical should be grounded. The primary coil is as above, the secondary (spark) coil connects to a spark plug at each end.
Make sure your coils are around 5 ohms primary resistance measured with a decent ohmmeter, between 3 and 6 ohms at least. Other types of coils for electronic ignition particularly - and Kawi was an early user - may have very low primary resitance and will not work with points.
You need 12V at the black coil wire and a ground on the other wire when the respective points contact is closed. When the points contact opens you get a spark. Both plugs on one coil spark simultaneously so you have to have both plug leads connected to a grounded spark plug to get any spark. Don't operate a coil much with one or both plug wires off, they can spark internally (if there's no other way to discharge) and be ruined.
