Author Topic: So can you go downwind faster than windspeed?  (Read 3813 times)
Offline Inigo Montoya
« on: July 06, 2010, 01:31:01 PM »
Offline wannabridin
  • Patience made me a
  • -Garrett
Re: So can you go downwind faster than windspeed?
« Reply #1 on: July 06, 2010, 01:48:39 PM »
pretty freaking cool!  the visuals help clear up what exactly people were arguing about...  nice find!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #2 on: July 06, 2010, 01:51:14 PM »
Yeah, but it doesn't answer the really big question, can a plane take off on a conveyer belt?   ::) :)
« Reply #3 on: July 06, 2010, 02:07:33 PM »
bob...shut up! ;D  I thought you knew better than that! :D
Offline KeithTurk
« Reply #4 on: July 06, 2010, 02:11:49 PM »
Well....ahhh No .... unless the belt has some associated devices to create drag,  then the air passing below the plane would have it's own wind speed.... which would allow the aircraft to lift off the belt once the wind speed exceeded it's minimum take off speed.
Now the next question.... if your flying forward at 200mph and fire rockets.... will the 400mph rocket be going 600mph or 400mph?
Offline gmonkey
« Reply #5 on: July 06, 2010, 07:26:58 PM »
Depends on whether or not you're in a vacuum.
Big pile of 76 CB550F parts
'98 FZR600 purring like a chain-smoking kitten!
Offline tramp
« Reply #6 on: July 07, 2010, 01:14:26 PM »
OMG
i had hoped that we were done with this kind of thread
my head still hurts from the others
the rocket would still travel at 400mph
1974 750k
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: July 07, 2010, 01:22:14 PM »
He ruined all the fun by posting the answer right in the first post! ;D
« Reply #8 on: July 07, 2010, 02:22:35 PM »
I was under the impression that iceboats did that all along? according to this article they do. No news here.
Scroll to the bottom.
http://www.iceboat.org/faqiceboat.html
Offline KeithTurk
« Reply #9 on: July 07, 2010, 05:05:11 PM »
actually it would fly at it's maximum velocity for the propellant it had available  and would use significantly less Fuel to get to speed so it's top speed would likely be significantly higher then 400 but most likely well less then 600 as the Aero loading would go up radically with increased speeds...
Fun stuff if your in that business...
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: July 07, 2010, 05:15:22 PM »
If you're pissing into a 50mph headwind, how hard do you have to push to keep from getting your pants wet, and what injuries will you incur from pushing so hard?
Offline KeithTurk
« Reply #11 on: July 07, 2010, 05:25:26 PM »
Shoot that one is easy Gordon......  not hard at all.... Simply point it UP!!!
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: July 07, 2010, 05:29:00 PM »
Don't forget to close your mouth! :-X
Offline KeithTurk
« Reply #13 on: July 07, 2010, 05:49:36 PM »
Ya ThhiiinK??
Offline wannabridin
  • -Garrett
« Reply #14 on: July 08, 2010, 08:40:58 AM »
if a man speaks deep in a forest, and there's no woman there to hear him, is he still wrong??   ;D
Offline KeithTurk
« Reply #15 on: July 08, 2010, 11:06:29 AM »
Doesn't that depend on his approach speed and angle of descent?
Offline syth82
  • 1976 cb550f project
« Reply #16 on: July 08, 2010, 05:46:40 PM »
i think, with a 50mph wind, your best bet would be to lie down and hope it clears your hair....
-Luke
« Reply #17 on: July 08, 2010, 06:52:02 PM »
Of course he is. We are always wrong.  ;D
Offline Pinhead
  • 1979 CB652-ST
« Reply #18 on: July 08, 2010, 08:22:05 PM »
Depends on if the aircraft is fully functional or not. Since the original question doesn't quantify "aircraft," it must be assumed that the vehicle is a fully-functional aircraft which means it has a working engine. This means it will produce thrust independent of wheel speed.
So yes, the plane can take off on a conveyor; the wheels will just be spinning faster than if the aircraft was lifting off static ground.
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
« Reply #19 on: July 08, 2010, 10:24:11 PM »
Now you've done it....... ;D
