Author Topic: workin on my k6 all day and still need some advice  (Read 1133 times)
Offline worlddrum13
« on: July 06, 2010, 05:48:45 PM »
help a noob out? i have been working on my carbs all day. i fully cleaned everything inside. all the jets and tubes were cleaned. i even put new inline filters in. once i got it all back together i took it for a quick putt to check things out. this is whats happening
when i am putt'n around at low rpms, i have to have the choke on almost all the way. otherwise its very sluggish and sputtery. as i go up in rpms i have to slowly turn the choke off. the higher the rpms and faster i go, the less choke is required.
it was pretty hot here in new hampshire today, so i doubt it needed to be "warmed up". and i was riding it for about 25 minutes and still no change in behavior.
a little about the bike. 75 750k6. pods, rather open 4-1, 110 mj, air screw all the way in. i dont want to start another "pod" thread, just sayin what it has. i built it from the ground up over the past two years from a bucket of parts that sat for 20+ years. i used what i had and what i could afford. :)
it seems lean? thats what i guessed. but i put the air screws all the way in and put larger jets in. (had 105s). any help? thanks
ii
75 750 k6
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
Re: workin on my k6 all day and still need some advice
« Reply #1 on: July 06, 2010, 06:22:43 PM »
 ??? Don't put your air screws all the way in. They should be 1 turn out, see how it runs and then adjust. See this thread in FAQ
http://forums.sohc4.net/index.php?topic=5410.0
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline worlddrum13
« Reply #2 on: July 06, 2010, 06:44:04 PM »
brought them all the way in and backed them out about 1 turn each. same thing. no noticeable diffrence.   ????
75 750 k6
Offline zzpete
  • You better get an
« Reply #3 on: July 06, 2010, 06:57:20 PM »
 ??? plugged slow jets? Air leak? What condition are your intakes in?
Offline Popwood
« Reply #4 on: July 06, 2010, 07:16:54 PM »
Feelin' your pain, Worlddrum. Having carb issues with my K5. I'll follow your post for tips and if you want to follow mine, check it out
http://forums.sohc4.net/index.php?topic=73544.0
Good luck.
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: July 06, 2010, 08:14:34 PM »
With pods and more free-flowing exhaust you're most likely going to have to go up more than one step on the jetting.
Offline worlddrum13
« Reply #6 on: July 07, 2010, 10:38:23 AM »
issue is resolved....however the old timers arent going to like this :)
i know it had to be running lean. i was pretty sure bigger jets would solve the issue. being the tinker'er that i am i took my 105 jets that i ws not using, found one of those precision screw driver sets, found the size that slipped right in, and took the size up and bored through them. :) im not saying this is a permenant fix, nor am i suggesting anywone does this to there jets. but i had a spare set and i got lucky with the sizes. i had 110s in it now i have 110+. i am going to order a jet kit next to see if i can dial it in more. although, i cant argue with the results. this is the smothest and nicest the bike has ran sincei put her together.
75 750 k6
