Support the site. Your contributions keep this site running.
0 Members and 9 Guests are viewing this topic.
That is if you are running with a magneto and no battery usually.
I read somewhere you could use a capacitor something in the 1000uF range to provide a load for the regulator and the alternator as well as to store an initial charge to give the first spark.
Quote from: CB750Ken8 on July 07, 2010, 03:59:12 pmI read somewhere you could use a capacitor something in the 1000uF range to provide a load for the regulator and the alternator as well as to store an initial charge to give the first spark.maybe something like this?http://www.oregonmotorcycleparts.com/BEC.html
Won't work with the 350F as it has an field coil (electromagnet) stator instead of a permanent magnet. That cap needs a permanent magnet.
Quote from: sir funk on July 18, 2012, 06:48:54 amWon't work with the 350F as it has an field coil (electromagnet) stator instead of a permanent magnet. That cap needs a permanent magnet. ohthxwhich CB models would it then work with? 500? 550?
I think all the SOHCs (350,400,500,550,750) have a similar stator setup. The 650 and 750 DOHC stilll have the field coil, but its a different design. I think the cb350, cl/cb450 twins all have a permanent magnet, and I would guess some of the other same era honda twins would as well.
