Author Topic: camshaft 1971 cb500  (Read 690 times)
Offline snowcap
camshaft 1971 cb500
« on: July 08, 2010, 06:56:43 PM »
Can anyone tell me for sure where to set the timing mark on the breaker plate when putting the camshaft and sprocket back together? I am using a clymers book and
believe it should be on the " t "of 1-4 mark while the right end of the camshaft notch is level with the block.Is this right?
Re: camshaft 1971 cb500
« Reply #1 on: July 08, 2010, 09:30:04 PM »
The line on the advancer associated with the "T" mark for 1-4 should be in line with the static mark on the case and the top line of the head casting should bisect the notch in the cam end
Offline Motoguy23
« Reply #2 on: July 08, 2010, 11:10:04 PM »
Static? Bisect? Associated? Stop trying to confuse people!  Or is it just me? ;D
All glory to the hypno-toad.
Offline snowcap
« Reply #3 on: July 09, 2010, 06:23:41 AM »
Thanks Bryanj , I will have to reset it , as I set it on the " f " mark the first time. Thanks
