Author Topic: Safe, Simple Chemical removal of busted taps\bolts\etc.  (Read 22407 times)
Offline fantino
« on: July 08, 2010, 11:59:42 PM »
Petty much everyone has been there, that gut wrenching moment when you snap off a bolt, or even worse, a tap into your crankcases or some other expensive and hard to replace part. I always had a bear of a time removing things like taps and bolts, maybe I'm just a little ham fisted or maybe I just don't have (and won't pay) for the right tools. Well luckily a little science solves all our problems.
You can dissolve ferrous metals out of non-ferrous metals (such as aluminum, bronze, etc.) with alum (potassium aluminum sulfate). It's a sour tasting pickling spice sold at grocery stores (try your local food co-op) that helps crisp pickled vegetables.
Submerge the offending part into a pyrex dish (you don't want to do this in a steel pot!!!) full of a solution of 4tbsp alum to 1 cup water (as much as you need to completely cover the bolt hole), I then placed the pyrex dish into a pot full of nearly boiling water and let it go. Heat is ESSENTIAL, or the alum won't dissolve. You'll see the steel part start to bubble a little bit (it's letting off pure oxygen) as the alum goes to town.
This isn't the fastest process in the world, it took me about 12 hours before enough of the tap dissolved to get it out. You could probably drill out the center of a bolt to help remove the bulk of the metal and then use the alum to dissolve away the rest leaving perfectly preserved threads. You can also either let it go until the part is completely dissolved, or you can speed things up by breaking little bits off with a sharp pick every hour or so.
The real draw is that there's relatively minimal labor involved, it's really cheap (~$3 per application), totally safe and odorless (let the solution get cold and the alum will form into big crystals you can just save or throw away), and really hard to mess up. Plus if your threads aren't already ruined up, they will be perfectly preserved!
Hope this helps someone out!
Offline hoodellyhoo
  • CB350F
Re: Safe, Simple Chemical removal of busted taps\bolts\etc.
« Reply #1 on: July 11, 2010, 07:06:29 AM »
We need pics! And someone else to verify this. Sounds very interesting!
Offline Ricky_Racer
« Reply #2 on: July 11, 2010, 03:47:04 PM »
Sounds like a good solution (pardon the pun!) for frozen brake bleeders.  :)  RR
« Reply #3 on: July 11, 2010, 09:14:51 PM »
 Are you talking removing ferrous bits stuck in a non-ferrous assembly.. and nothing else.
 I have to ask, any discoloration or etching on the non ferrous?
 any difference noted in hardened vs soft ferrous? ie, the bolt and EZsnap corrodes equally?..or one more than the other?...
 my curious mind needs to know...
Offline fantino
« Reply #4 on: July 12, 2010, 03:10:57 AM »
Unfortunately I did not document my process (perhaps I'll find a piece to demonstrate on).
And 754, it's only useful for removing ferrous metals stuck in non-ferrous metals (I guess theoretically you could remove everything surrounding a non-ferrous piece, but that would take FOREVER!). The alum reacts with iron, and little else, it seems.
There was definitely NO etching on the aluminum I tried it on. The submerged portion took on a darker color after I let it sit soaking in the solution overnight (not effective cold, unfortunately!!!), but that seems to be more an effect of being in water for an extended time. After it dried out and I wiped the darker bit down with a cloth (oxidation?) it was the same color again.
My case had mostly hardened steel (tap) and a small remnant of a snapped off metal tool wedged between it. The softer steel definitely seemed to dissolve quicker, but it my have just appeared that way because it wasn't as stuck and fell out sooner.
Hope that helps!
Offline luder
« Reply #5 on: July 13, 2010, 10:39:49 AM »
Now that was interesting.
Offline snowfighter2
  • I really like Motorcycles, I guess that makes me an
« Reply #6 on: May 07, 2013, 07:31:06 AM »
That is a great trick! Better living thru chemistry, as my doctor would say.
Andrew
That which does not kill you, will give you some awesome scabs, which turn into some cool scars!
1975 CB750K5
1985 GS 450E
1981 CB650 Custom
