Author Topic: attaching emblems  (Read 1430 times)
Offline octagon
attaching emblems
« on: July 09, 2010, 05:53:57 PM »
there's a thick black putty that's very sticky that they use to attach car windshields - don't know what it's called - but has anybody used this stuff to attach tank or side cover emblems?
Offline wardenerd
  • '77 550F '81 650C
Re: attaching emblems
« Reply #1 on: July 09, 2010, 06:01:45 PM »
yes be careful to seal around the emblem or air will get under it and literally blow it away.  my honda emblems have been on 2 years
Offline IndyFour
« Reply #2 on: July 09, 2010, 06:02:52 PM »
Sounds kind of messy and should you ever want to take the emblems off (like to repaint), you may destroy the emblems in the process.  I used double stick foam tape (the 3M exterior rated stuff).  There's no way those emblems are going to come off of there on their own.  If ever they need to come off, you just "saw" through the tape with tooth floss and peel/stretch the remaining tape off.  Just a suggestion.
1974 CB550K
2000 VFR800FIY
__________________
Indianapolis, Indiana
Offline vern401
« Reply #3 on: July 09, 2010, 06:03:24 PM »
No I haven't. It does not harden like you will want for the emblems. I'd use some kind of epoxy like JB wield to put them on with. It will not take much just a dab on the mounting pegs should do the trick.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
Offline Popwood
« Reply #4 on: July 09, 2010, 06:15:05 PM »
+1 on the 3M tape. Think to the future when you want to remove without destroying!
Current Rides:
1975 cb550K
1975 cb750K
1967 Bridgestone 350GTR
Past Rides:
1988 400 Hawk
195? Schwinn Whizzer
Offline hondaface75
« Reply #5 on: July 09, 2010, 07:36:40 PM »
One more for 3M :) Make sure your surfaces are clean and smooth, you wont have to worry about them coming off.
Offline octagon
« Reply #6 on: July 09, 2010, 08:15:36 PM »
the 3m tape sounds good - guess it holds up to heat - seems like that would be a concern, in ga anyway
Offline ev0lve
« Reply #7 on: July 09, 2010, 08:16:08 PM »
And another +1. Emblems have been attached for about 15 months now without a problem.
Offline octagon
« Reply #8 on: July 09, 2010, 09:06:02 PM »
thanks all, that's good to know
Offline Accolay
« Reply #9 on: July 09, 2010, 10:18:30 PM »
Are you guys just using the tape in addition to the little "emblem clamps" that went in there originally?
1977 CB550F
Offline ev0lve
« Reply #10 on: July 09, 2010, 10:27:46 PM »
No clamps, no posts, just tape
Offline Accolay
« Reply #11 on: July 09, 2010, 10:30:54 PM »
OIC.
I've been worried about mine flying off in the wind since I put everything back together. Maybe I'll pick up some tape as insurance.
1977 CB550F
Offline ev0lve
« Reply #12 on: July 09, 2010, 10:32:51 PM »
OIC.
The 3M double sided trim tape is crazy strong. I was worried about it until enough time had gone by I forgot to be worried about it. ;D
Edit: Forgot to mention my bike sits out in the rain and occasional sun all year as well. Good stuff that tape.
« Last Edit: July 09, 2010, 10:37:06 PM by Iggy »
Offline Gunner_CAF
« Reply #13 on: July 09, 2010, 10:38:56 PM »
I have used the 3M tape for tank badges on a bike, it's held up for a good two years and it's still holding strong.  Good stuff!
Gunner
66 CB77
73 CB500
83 XJ650
« Reply #14 on: July 10, 2010, 01:55:49 AM »
butyl mastic is the black sticky stuff,,it sort of semi hardens,,used in car body joins and seams,thats the aussie name.real stringy tacky gunk.
Offline Popwood
« Reply #15 on: July 10, 2010, 02:13:27 PM »
The emblems won't fly off with the 3M tape if properly applied-- meaning clean and sufficient surface contact. 3M knows what they are doing and the product is made specifically for this purpose, or at least for automotive use.
Current Rides:
1975 cb550K
1975 cb750K
Past Rides:
1988 400 Hawk
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #16 on: July 10, 2010, 02:19:46 PM »
The 3M tape is amazing stuff. Do it but mind what thickness you buy.
Offline kvallelunga
« Reply #17 on: July 10, 2010, 06:59:26 PM »
The butyl tape could sag in heat. I used a dab of clear silicone, my posts were broken off and it's been holding just fine for over a year now.
78 CB750 F Supersport
81 Yamaha Chappy
Offline Nikkisixx
« Reply #18 on: July 10, 2010, 07:46:09 PM »
3M double stick emblem tape: Nikkisixx tested and endorsed
Offline HellFishTat
  • I've UPGRADED to a '99 BMW R1100S
« Reply #19 on: July 11, 2010, 05:41:04 AM »
+ on 3m tape.  The stock badges on my '98 VT1100C3 were put on with tape.  My brother put the badges on his '60 FLH 14yrs ago and they are still attached.  Plus, if you decide to remove them, you can do so very easily with some fishing line.
Cheers!
and Ride Safe.
