Author Topic: Where to get cheap manometers? For tuning carbs  (Read 2703 times)
Offline campbmic
  • Sea-Foam and Flaming 151 is a dam good
« on: July 10, 2010, 12:30:25 am »
Just wondering where people find them cheap, I searched on eBay for carb tune and manometer but no motorcycle carb tuning tools came up? Any tips or good search words?
Its hard to be wrong when you know nothing!
Offline Gordon
  • 750K1, 550K2
Re: Where to get cheap manometers? For tuning carbs
« Reply #1 on: July 10, 2010, 12:37:51 am »
Define "cheap".
Offline eideteker
« Reply #2 on: July 10, 2010, 02:19:48 am »
My uncle gave me his old mercury gauge, so how's $free.50 for cheap?  8)
Searched eBay for "carbtune" and "carb sync" and the results are in the links.
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline CB750Ken8
  • I wanna ride...I wanna ride......Rawr MUST RIDE!
  • It's looking better everyday...jones'n to ride!!!
« Reply #3 on: July 10, 2010, 05:51:34 am »
I can't remember but either JC whitney or jp cycles has one for $49.99 which is the lowest price tag I've seen for a 4 cylinder manometer.
78' CB750 K8
Offline Bodi
« Reply #4 on: July 10, 2010, 12:28:02 pm »
I think mercury is now on the prohibited list with plutonium and grenades... not available in manometers to us home mechanic types and pretty hard to get at all. The cheap ones were all mercury manometers. Making water or oil filled manometers has been beat to death here but in essence you need a 30 odd foot high water manometer to avoid sucking the water out. There are oddball workarounds but I don't believe any work very well.
So you have either
1) four vacuum gauges, not a bad choice since even cheapo inaccurate gauges can be set to read almost the same at the vacuum level we're interested in but the gauges are bulky and fragile
or 2) the Morgan Carbtune which is really a flow gauge measuring airflow though a small orifice. It's compact, accurate, and almost indestructible.
