Author Topic: Not a SOHC, but a project for sure! '66 BSA Lightning  (Read 11031 times)
Offline putnaja1
  • '77 CB 550k -Was gonna cafe, but looks cool stock!
    • Jason's Wacky Website
Re: Not a SOHC, but a project for sure! '66 BSA Lightning
« Reply #25 on: August 29, 2010, 06:46:30 PM »
Rustoleum, "Stops Rust" primer.  So far so good!
Play Pinball!
My Gallery!
"The world is divided into people who do things, people who get the credit and people who continually criticize.  Try, if you can, to belong to the first class of people.  There's far less competition"
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #26 on: August 29, 2010, 06:51:56 PM »
Thanks.  ;D ;D ;D
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
« Reply #27 on: September 02, 2010, 06:52:56 PM »
Have you thought about "shooting" it with clear?
Offline putnaja1
« Reply #28 on: September 02, 2010, 09:01:20 PM »
Yep, a guy at work thinks I really ought to.. He says clear coat is harder than color coats..  I'm leaning towards wax however- because I figure scratches are inevitable, and without clear I ought to be able to do perfect touch ups? Still not completely convinced though that I shouldn't do clear..
What have you guys experienced with clear?  Good to do?
Play Pinball!
My Gallery!
Offline putnaja1
« Reply #29 on: September 26, 2010, 08:29:30 PM »
OK, it's been a while since I've updated..  Here's what I've been up to:
First, there are the seemingly endless "small" details to work on, for example, the gas tank name plate badges.  If you buy nice ones, they cost an arm and a leg!  Since this project is getting pieced together from the ground up, I am forcing myself to economize as much as possible on every part.  Otherwise it would be cheaper to just buy a new Triumph, and I don't really want to do that.  So, I bought some badges that would fit, but the finish was wrecked- much more reasonable in price:
I'm actually going to change them up a bit- I'll repaint the BSA letters and the little wing on the "B" white, and the letter background will also be repainted black.  But, I'll deviate from the stock scheme in that, the starburst background will be painted an orange-red, and the starburst will be polished metal, which in this case in copper-bronze in color.  Edges will remain metal color as well.
To get it ready for paint, I first enlist the help of a machine I first learned about/got for pinball machine restoration (another hobby of mine).  When fixing up those old pinball machines, you run across many rusted nuts/bolts/small metal parts.  It is prohibitively expensive to replace these old rusty metal parts (that is, if you can even find replacements).  A better and more economic solution is to use a vibration parts polisher- gun guys use them to polish their brass shell casings for reloading, and the pinball guys learned this trick from the gun guys.  I use corn cob media in this machine, add a few squirts of brasso and also some chrome polish, and throw the dirty/rusty parts in, letting the machine run for a few days.  Here's the machine:
Here's one of the badges after vibration polishing, during cleanup (to remove the corn-cob grit and wax build-up):
Hope to get some paint on these this week.  I'll try using Testors model paint, thinned out about 50/50?  I'll post here when I'm done, and show you how it goes.
Also, I finished the frame paint job by letting it cure, and then waxed many coats (polished out a few small imperfections too.  Looks good!)  I've started bolting parts on the frame:  Foot pegs (with special british-thread, reverse threaded splined stud shaft and locking plate (to keep the footpeg from rotating on the frame when you are trying to kick-start this beast!).
Finally, ignition switch, side-panel brackets, ignition coils, wiring harness, etc. :
Next up, install new swingarm bushings, re-finish the swingarm, and install along with new Girling shocks just received, then on to the fork rebuild and triple tree installation.  Then wheel rebuilds, and new tubes/tires.  Then I can put this machine on it's wheels, and then it will be a lot easier to move it around- this might allow me to clean out my garage/get all the sanding grit outta here before I rebuild my motor!!  :-)
Jason
« Last Edit: September 26, 2010, 08:36:49 PM by putnaja1 »
Play Pinball!
My Gallery!
Offline cb750k7
  • My CB AKA Charlie Brown...(K8 frame with K6 engine
« Reply #30 on: September 26, 2010, 11:59:18 PM »
Hi ,
Maybe this will be of help,  look at this site.
http://www.jwoodandcompany.com/2010/index.htm
Found real friends here !!!
« Reply #31 on: September 27, 2010, 06:30:47 AM »
Looks good!
jcassidy100
« Reply #32 on: December 01, 2010, 07:39:37 PM »
Hey, this project looks really great, I'm doing a similar deal with a 1970 Lightning only it was complete before the tear-down. Also planning a rattle can finish and then wax. Thanks for the images, looks like new. Where did you wind up getting the rims from, chrome, stainless or alloy and if you don't mind (I'm on a tight budget) how did they price out? Keep at it and thanks again.
Offline Toxic
« Reply #33 on: December 02, 2010, 07:14:51 AM »
Might I add that your flea market purchase for $500 was an incredible buy.
You got an awefull lot for your $500
Great looking project
Offline joeyputt
  • The green flag sets me free
    • www.dwmsracing.com
« Reply #34 on: December 03, 2010, 05:17:34 PM »
Man I just found this thread and could not stop reading it from start to finish! I love your build and can not wait to see what you do next, it is looking really good! Keep up the hard work and please keep the pic's coming!
Joe - Owner/Operator of DWMS Racing World Class Engine & Motorcycle Building www.dwmsracing.com
Facebook https://www.facebook.com/joe.dwmsracing
Offline hubbarbw
  • Swag
« Reply #35 on: June 23, 2012, 11:25:49 AM »
found this thread and hope your still at it!! i just got a 67 lightning on a rolling chassis, but its some custom hard-tail frame. im pretty amped to start building it and would love to see how your engine rebuild is going. i can use all the help i can get with these british bikes.
Offline RickB
    • Pop Magazine
« Reply #36 on: June 23, 2012, 12:50:58 PM »
Ohh good project. Personally I would be intimidated starting a British project just because of all those quirky British things as compared to the sewing machine-ness of the Honda's.
My best mate recently bought a restored 1972 BSA Lightning and he loves it. I got off my '75 CB400F and jumped onto it. Felt like riding a tractor! Sitting up in the wind, super hard gear changes, everything vibrating like a cement mixer. I can certainly understand the appeal, but it was a shock.
« Last Edit: June 23, 2012, 12:53:07 PM by RickB »
Offline lucky
« Reply #37 on: June 23, 2012, 10:27:05 PM »
Ah yes the old Whitworth tools. I still have a set of wrenches and sockets. I did a search and it looks like there are plenty of places to get them.
Whitworth #1 or Whitworth #2????
Offline lucky
« Reply #38 on: June 23, 2012, 10:28:33 PM »
Very cool project!!!! ;)
Offline benjy
« Reply #39 on: June 24, 2012, 08:33:06 AM »
Offline benjy
« Reply #40 on: June 24, 2012, 08:40:40 AM »
hey RickB,welcome to reality.nostalgia is very persuasive,+ we all fall into the trap.some harder than others.we read about + see these now not freely obtainable things,some which trigger old feelings which make us feel good.but your friends bsa isn't a bad example....they were just not great bikes + thats why the english auto industry(cars+bikes)collapsed
