All of the plugs look the same....white:(
Not what I asked, but interesting. Evenly hot head pipes mean that all cylinders are firing and that there is roughly equal jet flow from all four carbs.
These engines will run on three. But, the idle is poor and the engine doesn't make full power.
I did a bench sync with an 1/8 drill bit.
That's seldom good enough for a smooth idle. Vacuum sync compensates for breathing variations between cylinders. Such as, valve tappets not set equally for each cylinder, differences in cam lobes, etc.
Pulled the E tubes, pulled the pilot and soaked everything in cleaner, then cleaned the carbs with forced air. Replaced the old jets.
It's the overlooked details that hinder success. You replaced ALL jets? With what brand? What else did you replace? If you reused the old pilot jets, did you verify they could flow fuel, liquid, or light? Your statement makes everyone assume you did it all right. But, if all was right you wouldn't be posting a problem.
The filter is still the old filter, but in decent shape. However, one is in the mail.
You cannot tell by looking at it if it is ok, only if it is really, definitely bad. However, white plugs are seldom a symptom of a clogged air filter. And, you are doing the right thing by replacing it. So, 'nuf said about that
I suppose you are right about the timing light, however, I moved the plate and kept it wee the bike ran best. It worked with my other bikes:)
Do your other bikes hope to reach 10000 RPM? "By ear" timing is not recommended for these engines, unless you lust after overheated engines and holed pistons.
And certainly not if you desire a smooth idle. Uneven,incorrect timing = uneven, incorrect idle.
Is it possible the spark advancer is not working correctly?
Certainly possible. Another thing to check with a dynamic timing light.
I did not do anything with the tappets or cam chain. I was hoping to avoid fooling with that tappets.
You plan on avoiding all routine maintenance? The bike is doomed.
Would the float level have something to do with these symptoms? Perhaps too low? I read the post stating that a greater pull results in less fuel.
If the floats were so low as to starve the pilot jets, yes. Could you have installed them upside down?
Good luck!
