Author Topic: 75 550k Advice  (Read 2829 times)
Offline OldSchool_IsCool
  • Really feeling like an
Re: 75 550k Advice
« Reply #25 on: July 20, 2010, 12:49:50 AM »
OK EVERYONE......Here we go. Broke the POS tappet feeler i bought on EBAY. Anyone know where I can get a decent one(s)?
You can order them here
http://www.motionpro.com/motorcycle/tools/category/tappet_feeler_gauges/
Or look for them at you local neighborhood cycle shop.  Get the .002/.003 set and a .004/.005 set.  That way you can set the tappets with the GO/NOGO method.  For the intakes, if the .002 will fit, but the .003 won't, you got 'em spot on.  Likewise with the exhaust, if .003 is a GO and .004 is a NOGO then you're golden!
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline fletcha221
  • CENDSE BIKEWORKS
  • Cendse Bikeworks
    • OUR SHOP
Re: 75 550k Advice
« Reply #26 on: July 20, 2010, 06:54:54 AM »
AH! Ok, I downloaded another one, I believe it was the shop manual. This one explains the procedure for # 2 & 3. Thanks for the help guys!
Has anyone had any luck timing a sohc with a timing gun? I borrowed a "Inductive timing light". It says to clamp the inductive lead around the #1 Cyl sparkk wire, ground the negative, and run the positive to the battery terminal. I then start the bike. I'm, assuming I would then shoot the timing light into the inspection hole to observe the timing?? Given anyone's experience, should I retard or advance the timing on a 550? Or should a look for zero degrees?
I just want to make sure I do this correctly, so I'm not picking piston shards out of my forehead.
"Consistency is the last refuge of the unimaginative" -Oscar Wilde
1973 CB350f
1975 CB550k
1975 CB750 K5
Re: 75 550k Advice
« Reply #27 on: July 20, 2010, 08:44:15 AM »
The mark next to the "F" should align with the post groove when the light fires.
Must be at idle speed, or the advancer will change the mark position.
