Author Topic: Bad vibration at almost all speeds.  (Read 1091 times)
Offline UPHOTO
« on: July 15, 2010, 06:38:02 AM »
Not sure where to look first for this but it seems to be getting worse.
I get a strange up and down type vibration from the front wheel.  It shows up mostly at higher speeds especially when I come off the throttle.  It's a shaking up and down movement that is hard enough to shake my bar end mirror at times.
My fork seals are leaking, is this a sign that they are low in oil?  Or is this a wheel balance type of things?  I would think with wheel balance it would be just a vibration and not such a deliberate shaking.
Any ideas?
Sorry this is a 78 CB750F
« Last Edit: July 15, 2010, 07:29:35 AM by UPHOTO »
Re: Bad vibration at almost all speeds.
« Reply #1 on: July 15, 2010, 07:48:42 AM »
First, with the front wheel off the ground spin it to check to see if the rim is true and that the tire is properly mounted.
Too much fork oil can cause headshake, but if the seals are leaking anyway maybe it's a good time to disassemble for a good cleaning, new seals & oil.
Seals don't last forever, but often forktube pitting is a cause of leaks.
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #2 on: July 15, 2010, 10:49:02 AM »
After you check the rim, tire, etc. Check the steering head bearings, if their bad consider
using tapered roller bearings.
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
Offline UPHOTO
« Reply #3 on: July 15, 2010, 01:57:21 PM »
Thank you guys, I'll check into these when I get a chance.
Offline scunny
  • don't call me expert
« Reply #4 on: July 15, 2010, 03:16:14 PM »
don't forget tyre pressure
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: July 15, 2010, 03:37:12 PM »
And hop in the wheel.
Offline turboguzzi
« Reply #6 on: July 15, 2010, 03:40:25 PM »
And dont ride with leaking forks, oil will get on disc and pads just at the moment you need them most....
I am racing this weekend and just yesterday I discovered there was a very light leak in the forks, just back form the garage after changing the seals. It was a very light sweating but there were already traces on the calipers = bad for braking
TG
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #7 on: July 15, 2010, 03:57:32 PM »
Also check your engine mount bolts!!
I had a nasty vibration once and it turned out to
be a loose engine.
Bikes parked out front mean good chicken-fried steak inside.
