Author Topic: how to split a pressed together crank to remove the rod....xl125  (Read 2542 times)
Offline jaguar
im trying to find out the best way to remove the rod from a XX125 honda motor.
i know that its pressed together.
thanks for any help
Re: how to split a pressed together crank to remove the rod....xl125
« Reply #1 on: July 15, 2010, 07:23:26 PM »
How I did it was take it to a shop with the proper tools and expertise. Putting it back together and getting it to run true is much more difficult, by the way.
Offline scunny
  • don't call me expert
« Reply #2 on: July 15, 2010, 07:33:06 PM »
+1  had to do that to my GS1000, broke a conrod and took the new rod and crank to a local firm who have the gear. somethings are best left to others
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #3 on: July 15, 2010, 07:58:15 PM »
Very good advice
« Reply #4 on: July 16, 2010, 06:20:37 AM »
About a 50 ton press from memory
« Reply #5 on: July 16, 2010, 08:07:01 AM »
I had a buddy that would use my press and do them.. Main trick is to scribe them first.
 I am thinking, 20 or 25 tons will do most..
 He used what he called a CAN to do them, and we built a few. Basically a heavy tube with notch  for the rod, and a plate to support the flywheel halves, while pressing pin out or in. More than one cylinder, it gets more involved.
 Usually pressing involves shims to maintain side clearance, and assembly must be trued after pressing together. The key here is using the scribe lines, and a square to line up the bits on reassembly... one time he got it to 2 or 3 thou, just pressing it together.. very little truing on that one.
Offline simon#42
  • liverpool
« Reply #6 on: July 16, 2010, 10:43:14 AM »
i rebuild two stroke racing cranks as part of my business ,i use a 20 ton press and have several boxes of ' usefully shaped '
pieces of metal which i use for pressing cranks apart  .  the hard bit is getting them apart ,and back together perfectly square [ otherwise you will damage the flywheels ] truing the crank is pretty straight forward . if i where you i would take it to someone local who has a good reputation [ someone that does two stroke motocrossers might be a good place to look ], its not an expensive job and it might take you a few ruined cranks to get the hang of it
Offline jaguar
« Reply #7 on: July 16, 2010, 01:03:21 PM »
my goal is to take the rod off so i can model on for a CAD/cnc project that im trying to do.
my plan is to split the crank and re-install the new rod and pin.
