Its been a little while since my last update, but I've been pretty busy. I got the frame painted up in high gloss black, repainted the headlight bucket and my tach, put on my grips, disassembled my front brake to free up the stuck piston and stripped/shined them up. One of the other things I've been working on is starting to mount up all of my electrics. I am waiting for my tank/seat combo from Benjies Cafe Racer and I am planning on trying to mount the battery under the seat hump. I got all of my electrical components mounted up in a more discrete way already by finding a plastic container to mount them to....
After taking some measurements of the frame I went to target and found this box of plastic containers for about 5 dollars....
![](http://farm5.static.flickr.com/4131/4845305474_615b1f6bdb.jpg)
I took one of the plastic containers out, pulled off the little green handle, and spraypainted it black. Then I test fitted it by just setting it into the frame:
![](http://farm5.static.flickr.com/4151/4844687211_3df77b13a0.jpg)
Next, I went to the hardware store to get some nuts and bolts and proceeded to mount all of the components. Then I used some heavy duty cable ties and mounted the box into the frame. it seems to hide everything pretty well:
![](http://farm5.static.flickr.com/4149/4844687317_2c4ffd5746.jpg)
![](http://farm5.static.flickr.com/4104/4844687269_ab84d8527a.jpg)
Here is a pic of the bars with the grips and the painted tach and headlight bucket
![](http://farm5.static.flickr.com/4145/4844687343_672566ab89.jpg)
here is a pic of the brakes after freeing up the piston and stripping the paint with some light polishing. I still need to clean and shine up my forks
![](http://farm5.static.flickr.com/4113/4845305652_7aae362a57.jpg)
and finally here is the bike as it sits right now with the repainted frame and all the other stuff:
![](http://farm5.static.flickr.com/4113/4844687227_1ef3307485.jpg)
