Author Topic: Simple Green and Bearings  (Read 2608 times)
Offline SKTP
« on: July 16, 2010, 10:06:05 AM »
So I am degreasing my torn-down engine and was wondering if you guys have any thoughts on leaving the entire gear w/bearing spindles in Simple green...will that rust up my bearings or if I dry them and relube them will they be OK?
Also how about the crank shaft? Anything to look out for with that in regards to soaking and cleaning?
My internal engine parts are black and I am tired of them being that dirty...So far I have soaked some covers and the shift drum selector of 24 hours and am very impressed with Simple Green's results.
* edit how about Rubber? Any Simple Green issues with rubber or plastic?
« Last Edit: July 16, 2010, 11:16:06 AM by SKTP »
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline ludo410
Re: Simple Green and Bearings
« Reply #1 on: July 16, 2010, 10:39:35 AM »
it all depends on the barring i have done it before with mixed results. i guess what it boils down to if the barring is worn out. just make sure you soak them in clean oil as soon as you get them rinsed and dried. i prefer mineral spirits or kerosine/paraffin. as for rubber for me they always seem to get greasy like the rubber it self has instead of getting clean it has absorbed the grime
Offline sparty
  • I just play one on TV
    • Gallery
« Reply #2 on: July 16, 2010, 11:31:45 AM »
Take an empty bean can or any small can and drop the bearings in it.  Add kerosine and swish around, empty kero into a larger container and repeat until the kerosine is clean.  Use the dirty kero on your next camp fire.  As for the rubber, no problem with Simple Green, just wash off with mild soap and water then just water.
Sparty
1972 CB750 K2 Cafe' Style
Offline gmonkey
« Reply #3 on: July 16, 2010, 11:38:25 AM »
I don't know about the bearings which I'm guessing are steel but Simple Green affects aluminum.  Actually says so on the bottle.  Creates some of that white corrosion powder and discolors the metal itself.  Takes a while but something to keep in mind.
Big pile of 76 CB550F parts
'98 FZR600 purring like a chain-smoking kitten!
Offline OrganDonor
    • My other hobby...
« Reply #4 on: July 16, 2010, 12:20:11 PM »
I'd do what Sparty recommended.  I use Simple Green to clean out scuba tanks specifically because it leaves behind no organic film.  But I have to be extremely careful to dry them out thoroughly right after rinsing to prevent flash rust from forming.  For that reason, I'd clean internal engine parts with a solvent and use the Simple Green for the plastics.
77 CB500K
80 CB650 Custom
76 CB750K
« Reply #5 on: July 16, 2010, 01:58:27 PM »
Simple Green will attack chrome and many bearings have a plating on them. the safest solvent is the oldest also. It is called kerosene, which has a much lower flaspoint that gasolene or other solvents. Let it soak for as long as you can and brush away the crud.  It also leaves and oily film to prevent flash rust. Old school?, maybe not, they list kero as petroluem distillates on a lot of things like WD-40 and some engine cleaning additives.
