Author Topic: how to turn the odometer to zero?  (Read 8996 times)
Offline mazingerzeca
« on: July 16, 2010, 05:47:33 PM »
Nothing illegal about it. I've just rebuilt my engine and would like the odometer to show 000000 again.
Offline scunny
  • don't call me expert
Re: how to turn the odometer to zero?
« Reply #1 on: July 16, 2010, 05:50:04 PM »
ride backwards for 40000 k's
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
« Reply #2 on: July 16, 2010, 05:53:35 PM »
Once you open the case it is really easy, the hard part is getting the case open without messing it up. There are threads that show you how to open the case without too much damage.
Offline nokrome
« Reply #3 on: July 16, 2010, 05:56:04 PM »
once you have the case open what do you do ?
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
« Reply #4 on: July 16, 2010, 06:01:02 PM »
Connect the speedo cable to a drill and run it in reverse, use tape to keep the trigger on.
Offline Frankenkit
  • Industrial Strength
« Reply #5 on: July 16, 2010, 06:32:44 PM »
Conversely, if you're one of those guys who trailers his bike to Sturgis, Daytona, etc, you can do the reverse and put miles on your paperweight bike.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #6 on: July 16, 2010, 06:54:59 PM »
Not really, think of the steering that would be bad! :D
« Last Edit: July 16, 2010, 06:56:35 PM by cb350twin »
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline mick750F
« Reply #7 on: July 16, 2010, 07:17:04 PM »
   Well cha...how else did I get 10K miles on my Lazy Boy/Barcalounger? ;D ;D ;D
Mike
Glosta, MA
Offline CB750Ken8
  • I wanna ride...I wanna ride......Rawr MUST RIDE!
  • It's looking better everyday...jones'n to ride!!!
« Reply #8 on: July 16, 2010, 09:45:18 PM »
Get a spare cable and connect to a drill, pull trig and wait for it to roll over.
78' CB750 K8
Offline cookindaddy
  • I sure love this bike!
« Reply #9 on: July 17, 2010, 02:27:52 AM »
About turning it backwards - the speedo needle will be pushing against the 0 peg. It won't damage it to be doing this? How fast do you go with the drill? I don't know what the mechanism is like since I haven't taken one apart yet. Is it a magnetic cup pushing against a spring?
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Bodi
« Reply #10 on: July 17, 2010, 05:28:54 AM »
Find a new speedometer?
I don't understand about the illegal part - it's not illegal to replace a speedo, just illegal to fraudulently represent the resulting vehicle as having low mileage to a prospective buyer. Regardless, the mileage is on the vehicle not any component. Should I zero the mileage on my car when I replace the tires? Despite your honesty the bike will have a false mileage and future owners may not be as scrupulous.
The instruments are not designed to be opened but like most such things you can do it. The sealing ring will never look right again afterwards. Once the case is open you can disassemble the odometer number reel assembly and set it to any number you like but it unless you're a watchmaker it is a bit of a challenge. It wasn't made to be disassembled either but there's no anti-tamper mechanism like (so I've heard...) many car speedos have.
On balance I suggest marking the rebuild mileage somewhere and not resetting the odometer.
Offline Johnie
« Reply #11 on: July 17, 2010, 05:57:13 AM »
I swapped a better speedo with my K1 and it actually had like 10,000 more miles on it. I had the unit all apart and could not see how to set it back to match the speedo miles that I took off. It looked pretty complicated in there and I did not want to mess it up. I left it as is.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline tweakin
  • tear down
« Reply #12 on: July 17, 2010, 06:10:45 AM »
This is real easy once the speedo is apart like above.  There is a small c-clip on the side of the number rolls (I believe on the left side).  Carefully remove this clip with some small needle nose pliars.  This allows you to move each number roll to the side and free it off its guide.  Now you can move each off the 6 rolls back to zero.  next slide each one back to its original location and then re install the c-clip.  Done.  speedo odometer reads zero.
« Last Edit: July 17, 2010, 10:28:45 AM by tweakin »
Offline Johnie
« Reply #13 on: July 17, 2010, 10:02:35 AM »
Geez...that sounds not bad at all. I will keep that in printed form for later...
Oshkosh, WI  USA
« Reply #14 on: July 17, 2010, 10:04:47 AM »
This is real easy once the speedo is apart like above.  There is a small c-clip on the side of the number rolls (I believe on the left side).  Carefully remove this clip with some small needle nose pliars.  This allows you to move each number roll to the side and free it off its guide.  know you can move each off the 6 rolls back to zero.  next slide each one back to its original location and then re install the c-clip.  Done.  speedo odometer reads zero.
Clean lookin' faces!
Offline cookindaddy
« Reply #15 on: July 17, 2010, 12:13:23 PM »
Very nice gage faces meriggi!
Can you tell us how these were done?
« Reply #16 on: July 17, 2010, 01:28:06 PM »
Not mine!  Tweakin??
Offline Quorthon
  • Pace till death
« Reply #17 on: July 17, 2010, 01:28:29 PM »
I agree with this.  I hate it when people list vehicles as "Low mileage!!!!"  When they rebuilt the motor but the vehicle has a million miles on it.
Leave the odo alone and say what real mileage it has, and xxxxx since the rebuild.
1972 cb500/4
« Reply #18 on: July 17, 2010, 02:35:36 PM »
As I stated, nothing illegal about it. I've never sold a bike and I'm not thinking on selling it at a low mileage. I have some other speedometers, with different mileages. In fact, the one I'm using is not from this bike, and does not show the bike's real mileage, which in fact I don't know exactly. I just want to show it 0000 for practical reasons, such is mileage for oil changes, filters, tyres and so on. Yes, of course I can add these miles (or Km, in my case, to the ones that the speedo shows). The bike has been rebuilt with parts from different bikes, and obviously, I'm not thinking in terms of sandcast or pretending that the bike comes from a 1970 crate with 0000 miles on it.
When I said that I'm not trying to make something illegal I referred to the people that sells bikes or cars showing a mileage that the vehicle doesn't have, or the manipulation of the odometer to obtain a cheaper insurance based on a low mileage per year.
« Last Edit: July 17, 2010, 02:56:41 PM by mazingerzeca »
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
Offline markb
  • When I finish my current project I might be a
« Reply #20 on: August 03, 2010, 04:10:49 PM »
I have no problem with resetting the odometer to 0 on a bike that's 30 to 40 years old after its been restored.  I'm not going to believe the odometer anyway on one that old and the mileage is not required on the title either.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #21 on: August 03, 2010, 04:47:13 PM »
Mark
+1  Probably not the original gauge anyway.
