Author Topic: starting problem  (Read 785 times)
Offline Muk
  • WHY OH WHY DIDN'T I TAKE THE BLUE PILL
starting problem
« on: July 17, 2010, 07:44:51 PM »
I have tried 3 different new batteries. 1 from autozone, 1 from Oreilly, and one from advance. none of these will crank the bike over, the closest was the a/z battery it did hlaf a revolution. the battery voltage drops to 6v while cranking and i have tried voltage drop testing and found nothing. is it possible to get 3 bad batteries or could it be the starter. i have removed the starter and the armature looks clean and the brushes are plenty thick. i need ideas! if it is junk batteries where should i get one? also fyi i do not have a 700ma charger, but i use a 2a automatic charger that i have used for several batteries and never had an issue with it before. i am just at my wits end here.
1976 CB550K
1978 GS750E
1980 GS550E
Offline vern401
Re: starting problem
« Reply #1 on: July 17, 2010, 07:58:31 PM »
Get a reading of the battery before trying to start the bike. It is real unusual that you would get that many bad bateries. My thoughts are something is pulling down the starting system hard.
Pull the starter and test to with the battery off the bike. see if it is pulling allot of juice.
What is the difference in battery voltage from key off to key on?
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
« Reply #2 on: July 17, 2010, 08:01:00 PM »
Could be starter or bad connection. Check voltage as vern suggests.
Can you kick start?
Offline tgtint
« Reply #3 on: July 17, 2010, 08:31:55 PM »
are you charging the batteries or the auto parts store?
1973 CB750
Offline Spanner 1
« Reply #4 on: July 17, 2010, 08:37:40 PM »
Will the starter spin like mad out of the motor when connected to the battery... hope you tried that while it was out of the bike ?
If it was good, look at 3 things, first the + cable where it passes thru' the starter cover for possible short to ground, the battery ground wire connection at the frame and the solenoid ( jump the big terminals with a heavy piece of wire )...... good luck.
Offline Muk
« Reply #5 on: July 18, 2010, 03:44:59 PM »
update. i took the starter out and it would only spin half the times that i tried it. and when it did it sounded horrible. went up the  m/c junk yard and got one and now it starts great.
1976 CB550K
1978 GS750E
1980 GS550E
« Reply #6 on: July 18, 2010, 04:18:47 PM »
Good to hear! Don't you love those cheap/easy fixes?
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #7 on: July 18, 2010, 04:57:05 PM »
So it wasn't really a junk yard after all. A gold mine I reckon.  ;)
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
