Author Topic: CB750 F 1977 model series wire harness  (Read 2068 times)
Offline coolgoose
« on: July 18, 2010, 10:31:17 PM »
Are all the  F series models (F0, F1, F2 and F3) have same wire harness or they different? Where do you guys buy wire harness for F series? I was looking at yamiya and found that it is a specialty store for K series only. I am planning to get my friends CB 750 F2 (1977) and started compiling a list for parts before I start working on it.
Thanks Guys!
Re: CB750 F 1977 model series wire harness
« Reply #1 on: July 18, 2010, 10:55:06 PM »
75/76F harnesses are different than 77/78F.
Where do we get them? Generally we don't. I have seen 2 NOS 75/76 harnesses on EBay in 4+ years of daily watching. Bought one and let the other go. $150 & I considered myself lucky. You will probably be stuck overhauling it with new connectors and wiring if needed.
Offline jtb
  • An unlikely
« Reply #2 on: July 19, 2010, 05:33:35 PM »
 I got a 77/78 on ebay a few years ago, and ended up re-doing the original.  I think I saw one on ebay a couple of days ago.  You can buy the bullet connectors from http://www.vintageconnections.com.
1977 CB750F
1985 V65 Sabre
Offline coolgoose
« Reply #3 on: July 19, 2010, 06:46:59 PM »
Thanks guys for the responses! So If I understand correctly,
If I get a 78F wire harness I can use it on my 77.  75/76 Wire harnesses cannot be used on 77/78 F models.
Offline doobiebro
« Reply #4 on: July 20, 2010, 07:49:45 AM »
The two harnesses could be interchanged, but it would take a little work.  There are subtle differences between the harnesses, of which the most obvious is the front brake light switch that is incorporated into the brake handle in the 77/78 models.  The ignition switch connector may also be different.
