Author Topic: Help! CB350F leaking lots of oil after rebuild???  (Read 643 times)
91greg325i
« on: July 19, 2010, 09:02:50 PM »
Just finished rebuilding my cb350f engine and it seems to have a large leak at a plug directly in front of the output drive (it is a ~1.25 inch round seal that is blocking off a hole in the cases)... I'm not sure what the purpose of the hole in the case is, but the more pressing issue is how to get the oil to stop coming out. Anyone with any suggestions, I'd love to hear them!
Thanks in Advance,
Greg
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
Re: Help! CB350F leaking lots of oil after rebuild???
« Reply #1 on: July 20, 2010, 01:53:43 AM »
I can't say for certain because I have a 550, but mine has a round seal in the same place & it's a seal at the end of the transmission mainshaft. Maybe you just need to replace it?
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
91greg325i
« Reply #2 on: July 20, 2010, 11:04:18 AM »
Well, I replaced it, which is the strange part that I'm having trouble with... Should I have put RTV on it, or something? The good thing is that it runs like new... except for all the leaking oil. Needless to say I'm getting anxious/worried that I may have to tear it all down again... I'll try cleaning it up/drying it off, then putting the seal back with some RTV, or something.
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #3 on: July 21, 2010, 12:29:40 AM »
Yes this is the main shaft oil seal. 34x9. Correct way to replace this seal is to split the crankcase, as it has a locating dowl as part of the seal. As a temporary fix you could cut the dowl off and fit with Hondabond or similar to hold it in place.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
