Author Topic: CB 650 grinding noise from starter  (Read 2164 times)
kvikly
« on: July 20, 2010, 03:22:30 PM »
Most of the time the starter makes a grinding noise, when I try to start the engine. A few times the starter will turn the engine, but most of the times it just makes a horrible noise. I've tried with an other starter, but with the same results.
Can anybody tell me how to fix the problem?
Kind regards
Per Hansen
Offline IainC
Re: CB 650 grinding noise from starter
« Reply #1 on: July 20, 2010, 03:38:45 PM »
I had this problem on my parts bike. We tried swapping in a starter motor that works fine, and still had the same problem. At that point we gave up as we figured it was a stripped gear inside the engine. We came to this conclusion as the problem got worse the more we tried to use the starter.
Offline The_Crippler
  • Work in progress.
« Reply #2 on: July 20, 2010, 04:19:42 PM »
Read up on the starter clutch.  From what I understand, it's not uncommon with the 650s.  Mine had been replaced by the PO shortly before I bought it - and that was with only 7K on the clock.  I have a spare one off of ebay that I'm keeping around just in case.
Offline cb650
« Reply #3 on: July 20, 2010, 04:21:23 PM »
Sounds like the starter clutch.   Here is a topik on the 650 site.
http://www.hondacb650.com/viewtopic.php?f=4&t=242
I did work on a bike with a bad one and we kept sppraying wd 40 in the starter hole. Seemed to help but not cure it.
kvikly
« Reply #4 on: July 21, 2010, 01:14:41 PM »
Thank you. Your answers are much appreciated. Especially the link to the 650 site. Now i know what to do next weekend!
Offline scunny
  • don't call me expert
« Reply #5 on: July 21, 2010, 01:17:30 PM »
I think you can get the starter clutch out thru the bottom with the oil pan off, worth a try anyway
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
  • Work in progress.
« Reply #6 on: July 21, 2010, 01:38:13 PM »
Really?  Wow...that'd be a lot easier than the clymer manual made it seem.  I'll have to look into that, should mine ever go again.
Seems to be an echo in here.   ;D ;D ;D Glad you had a link - I kinda had to do a fly-by posting last night and never had a chance to get back here and find one.
Offline Soos
« Reply #7 on: July 21, 2010, 02:56:56 PM »
Personally have not had that problem in all the 650's I have repaired or currently own.
It's GREAT to know there are instructions for an easy repair compared to having to split the case apart!!
The SOHC community rocks   ;D
L8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline cb650
« Reply #8 on: July 21, 2010, 04:32:59 PM »
I have only delt with 2 650's that needed it done.  One I aquired and its still waiting the other was one I was helping out with and he sold it before we got to it.  Was sounding better doing the wd 40 thing.
