Author Topic: Simple - get emblems off?  (Read 787 times)
SugarBike
« on: July 21, 2010, 11:19:13 AM »
Humm... how does one get the Honda tank emblems off, non-distructively?
No screws like I'm use to...
CB750K3
Offline Coyote13
Re: Simple - get emblems off?
« Reply #1 on: July 21, 2010, 11:21:27 AM »
Mine are screwed in (thanks to the PO), how are they normally attached? If they're adhesive I bet you could use a hairdryer on high heat, some fishing line, and goof off.  That's how I got the badges off the trunk of my car and it worked like a charm...
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline Really?
« Reply #2 on: July 21, 2010, 11:26:31 AM »
I had some thin safety wire in the box so I used that.  It is just wire.  I slid it behind the emblem until it stopped (at pin) and tugged with both hands slightly.  Popped off easy on momma's.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline zzpete
  • You better get an
  • 1969 CB750, 1971 CB750
« Reply #3 on: July 21, 2010, 11:30:52 AM »
They are pressed on. They come off with a plastic putty knife and patience! You can use fishing line also. Check out the following link.
http://forums.sohc4.net/index.php?topic=11701.0
"One of the things that make motorcycling so great because it never fails to give you a feeling of freedom and adventure." - Steve McQueen
« Reply #4 on: July 21, 2010, 11:41:09 AM »
Yes gentle pry with a putty knife. Alternate ends and middle, pry just a skosh each time to keep from bending the emblem.
each emblem has 2 pins, 1 located an inch or so from each end. These press into a friction nut, installed in a bracket in the tank, generally intended to be a one way affair. But go slow and they will come off. The friction nut sometimes comes off with the pins, or it stays in the tank where it belongs. Be sure to account for them for reassembly.
SugarBike
« Reply #5 on: July 21, 2010, 03:55:53 PM »
Thanks brethren.
