I was taught, absorbed this technique also. However, in a past thread here on the issue, an expert (BobbyR?) in the field of torquing, let us know that some torque values (most?) take into account clean DRY hardware. So that threw a wrench into my belief system.
Since most of our torque amounts are in pretty wide ranges, I'm not too concerned. Will likely do head nuts and such dry from now on. or until I learn better, again.
[/quote]
MCRider
Thank for the update. I didn't know that. 'Wonder which torque wrench accounts for "dry" and which don't. Also, when did the tool mfg's start this?
I can't disagree with your info. However, since my tools are getting old, like me, I'm gonna stick to the "lube the threads" rule. It worked for the engine builder I mentioned over TOO MANY years.
Thanks much
[/quote]
If memory serves, it wasn't the tool mfgs but the shop manual printers. All quoted values are assumed dry, is what I gathered from the discussion.
Still I also prefer the logic of lubing the threads first, it seems more elegant, and as you say evidence is it mustn't matter.
I did a search and found lots of perspective
http://www.dansmc.com/bolts2.htmAnd amazing in my Google search I turned up this:
http://forums.sohc4.net/index.php?action=printpage;topic=63819.0And this one has good comments
http://www.thumpertalk.com/forum/archive/index.php/t-200128.htmlIf you accept the premise that a lubed bolt should have 20% less torque, then looking at the head nuts for example:
http://www.salocal.com/sohc/tech/torquetable.htmThe upper range is 18.1 and 80% of that is the lower range of 14.48.
So I'd probably lube it or anti seize it and go to 16.
