Author Topic: CB550f Carb overflowing with gas  (Read 825 times)
Offline gravano
« on: July 21, 2010, 09:58:53 PM »
So the runoff is running over. Does that mean the float or float needle is dirty?
Offline vern401
Re: CB550f Carb overflowing with gas
« Reply #1 on: July 21, 2010, 10:02:39 PM »
Yes it is hanging open for some reason. try tapping lightly on the side of the carb to free it. or open it up and look for anything in the bowl, or valve that may be causing the problem.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
« Reply #2 on: July 21, 2010, 10:37:15 PM »
Where is it leaking?  The stand pipes in the carb bowls can crack.
Offline gravano
« Reply #3 on: July 22, 2010, 06:26:38 AM »
It's coming out of the overflow so I think the float may be stuck or whatever the pin is that holds the float.
« Reply #4 on: July 22, 2010, 06:49:18 AM »
when the bowl is off, fill it with water(but stay under the stand pipe) and check for a leak out the overflow.
if it does, the pipe is cracked and in need of repair.
if no leak, and you are positive your floats are set correctly, then the fuel valve is not closing when the float rises against it..  its gummed up with something, or the spring in it is fubar.
Offline gravano
« Reply #5 on: July 22, 2010, 07:48:33 AM »
Thanks all.
This happened after I installed new throttle cables, but the bowl looks like it's had a small leak for a little while.
I probably just hadn't noticed and somehow it got worse.
