Author Topic: My little SL350 rebuild thread  (Read 23551 times)
Offline MoMo
  • Ride like you're invisible
Re: This SL350 K0 rebuild is gonna be a cake walk . . . isn't it?
« Reply #25 on: October 20, 2010, 06:04:15 AM »
Interesting thread and very good work.  FYI, back in the 70's the shop I worked for sponsored a rider by the name of Alfie Hendricks, who rode an SL350 as the top enduro  rider in New Jersey/PA.  An amazing feat considering the weight and competition(Maico, Husky, etc.)
Offline the-chauffeur
« Reply #26 on: May 04, 2011, 06:37:23 PM »
Postscript
Having had the bike out and about for a bit now, I thought I'd add a few observations and words of, ahem, wisdom for anyone contemplating the same exercise.  Some of these are SL specific; others are more general:
- the rear wheel alignment marks on the swingarm almost certainly don't.  Set up the rear end measuring from the centre of the swingarm pivot bolt to the centre of the rear axle each side BUT look very carefully at how close the chain runs to the lower rear chainguard.   My chain came into contact with the lower guard at some point because . . .
- unless you're very lucky, 40+ year old shock dampers probably won't.  Turns out mine had lost pretty much all their fluid, but I only really found that out when I rode the bike for more than fifteen miles in one go and nearly broke my arse.  The shocks are 335mm long (same as the CB750 K's) and if the damping's gone, you'll just wobble about a lot and the chain will trash the lower guard
- the effects of a lack of damping weren't helped by the wheels being unbalanced as a result of my desire to keep the bike as original as possible by refitting the security bolts (part #10 in this diagram).  There's one in the front wheel and two in the rear.  I'm all for originality, but not when it causes the bike to shake itself to pieces at anything over 35mph.  If you want a museum/concourse/show only piece, keep the security bolts; if you want a usable machine, rebuild the bike without them and keep them in a bag to pass on to the next owner
- use lots of lockwashers and threadlock.  Check and retighten all of the nuts and bolts you can reach, particularly those holding the top end on
- don't assume aged clutch plates will hold together, even if they've only got 7k miles on them - or that they will put up with more modern semi-synthetic oils.  Yes, they slip; and yes, they delaminate - all of which results in bits of friction material and tiny bits of aluminium (where the plates chew the clutch basket) ending up in the oil.  And yes, I've changed them now - and cleaned everything out twice for good measure
- speaking of the clutch, Dave Silvers do a clutch pack for the CB350 K2's, the contents of which (8 fibre plates, 4 clutch springs and a cover gasket) are interchangeable with the SL K0.  Which is nice.  Those bits will also fit the K1/K2s, with the exception of the gasket (engine sidecovers were different shapes)
- if you're going to put a coating of copper grease on the head gasket to help it seal/seat, make it a very thin one - and expect little pools of gold liquid to appear when the engine gets hot
- dented SL350 mufflers generally end up staying that way.  I've had mine appraised by several different professional services, none of whom could satisfactorily repair the three or four shallow dings in them for a variety of reasons.  Some are positional - for instance, anything near where the inner baffle joins the outer skin is a no-no; others are due to age - the metal is now thin and brittle, and can't tolerate heat, which more or less rules out brazing or silver soldering
- similarly, even a professional heatproof paint job won't hold up particularly well on these exhausts.  Despite having them bead blasted and properly prepped, heatproof paint isn't adhering as well as you'd expect - particularly to the mufflers.  I think the only other option now is to have them ceramic coated, but that can wait for winter
- most of the footrest bars are wonky - the right hand side will be angled up, with the left being more horizontal.  I thought the one that came with the bike might have been bent, but it turns out that was how they came out of the factory.  If you want both sides to be even remotely symmetrical, you'll need to cut and reweld one of the end mounts
Other than the shaky rides and general silliness of some of the above, I've been pleasantly surprised by how nice the bike is to ride (at slow speeds for now) - and at the comments it attracts, predominantly due to its scarcity.  I hadn't realised just how unusual the K0's are this side of the water - since I bought mine, I've seen only one other and that was a combination of parts with a much later CB motor fitted.  In financial terms, the build was (and still is) a bit of a disaster; I think I've said before that it cost me a whole lot more than I anticipated.  But that's not what it's about, is it?
« Last Edit: May 29, 2011, 04:42:58 PM by the-chauffeur »
« Reply #27 on: May 29, 2011, 02:51:34 PM »
I can't be doing with multiple threads on basically the same subject, so with a change of name (the thread, that is), I'm just gonna extend this one . . .
May 2011
Almost a year to the day after getting the K0, the draw of fleaBay proves to be too strong and as if by magic a relatively complete but scruffy K2 appears. For nine days, eleven hours, fifty nine minutes and fifty five seconds it sits there with no bids.  Mine goes in with five seconds to go and . . . holds breath . . . the auction ends and I've won.  A quick look at the ad reveals there was another bidder who came in with an identical bid to mine one second after me.  My bid wasn't the starting price, and it wasn't a round number - it was a strange figure.  Yikes, one second either way, huh?  And I'll apologise now if the bidder is reading this - that would have royally pissed me off, too.
Anyways, back to the bike.  A week after the auction ends and it's delivered.  I could've picked it up, but that would've required a seven hour round trip; not so bad if you're driving from, say Dayton to Chicago on long, straight, reasonably open roads, but not so good from one side of London to Manchester and all the congestion in between.  So a nice man in a van dropped it off at 7am on his way down to the coast - no, I've no idea what time he set out, but rather him than me.  So this is pretty much how it looked:
Initial impressions were that from a cosmetic perspective, most of the important parts were there in one form or another.  The keen-eyed among you will have already noticed that of the big three, two of the hardest to find parts were there - exhausts and seat.  By some stroke of luck, I'd found a pair of side panels about three months before I bought the bike - again, scruffy but complete - but more on those later.  The wheel rims are straight and more remarkably, just about unmarked.  The mudguards are pretty straight, if scratched up a bit.  Seat cover's never gonna put any work in again, but the pan looks good.  One big advantage it has over the K0 is that the forks are, like the wheel rims, straight and unmarked.  And like the K0, the mufflers are in the right number of pieces but dinged about a bit.  Unsurprisingly, the control cables are all shot to pieces; dried out and crumbling and falling apart in all manner of exciting ways.  And I'll need to do something about the clock(s):
The engine, whilst covered in crap from fields, is all good from five foot away.  Shuffle a bit closer and you can see the first sign that the bike hasn't spent all of its life on its wheels.  The brake pedal has been pushed up against the right hand cover and whilst the case itself is still solid, it's got a deep gouge in it.  Hang on - the bars turn much further to the left than the right - yeah, the lower yoke lockstop on the frame has been pushed to one side.  Back to the engine.  All of the fins are in tact, the head's not got a mark on it, and the engine turns over relatively easily and has some sort of fluid in it . . . which seems like a good sign.  The carbs aren't quite so good; although the sliders seem to move freely, one of the breather spigots has snapped off the side of the left hand carb, and most of the adjuster screws are chewed to hell, snapped off or missing.  Talking of strange fluids, I nearly forgot about the tank.  It too has fluid in it, which I assume was petrol at one time.  Not any more; filthy, orange and smelly, more closely resembling varnish than fuel.  The tank's been repaired and repainted at some point in its life but not very well.
All in all, not as bad as it could have been - given it's relative rarity over here.  I saw a shed of a K2 that some clown had made into a chopper sell a few months back for a couple of hundred less than this, so I can't help feeling pretty pleased.  But I haven't started tearing into it yet, and the K0 taught me that the insides of the engine could hold a number of surprises . . .
« Last Edit: May 29, 2011, 04:45:27 PM by the-chauffeur »
Re: My little SL350 rebuild thread
« Reply #28 on: May 29, 2011, 03:35:09 PM »
Teardown
Unlike the K0, it quickly becomes apparent the K2 has been used for more than just transport in the past.  It's been a mobile home to a few creatures.  Separating the air tubes from the carbs reveals a fair quantity of wasp remains, and I'm sure something flew out under its own steam.  And then I gave the seat a shake:
Mouses.  None there now, I'm pleased to say, but there's evidence of some very small four legged creatures having sheltered under the seat.  I'm sure I'll see the extent of their handiwork when I pull the seat apart.
Like the K0, the consumables are long gone.  The electrics are dirty and one previous owner has decided that a fuse added too much weight, so it'd be better to just ditch it and the holder.  And like the K0, all the signs suggest the bike was last used in a field and then stored in a barn.  One nice touch - in the glove compartment(?) under the seat I find a road licence issued for the bike in '78.   It has the name and address of the owner - maybe I'll look him up when this is all done.
The licence plate shows the last time the bike was on the road - legally - was . . .
More good-and-bad news.  It's the small things . . . on the upside, this is the first old Honda I've bought where one key fits (and works) all the locks - including the steering lock; the chrome looks pretty good under all the crap and it's got the rare-ish plastic chainguard, toolbox and very rare horn switch. The downsides include a busted battery tray (looks like it was cut to take a bigger battery), the toolbox lid is missing and the handlebars are wonky.  And while the plastic horn switch was a great find, the tab that holds the two halves together has snapped off.  There's also evidence of a chain having jumped the rear sprocket and chewed into the rear wheel hub.
Back to the frame, and it's going to need more work than I originally thought.  Along with the wonky lockstop, the right hand footpeg mounts are stripped out, and someone's tried to bodge one with a piece of threaded rod.  And one of the rear footpeg mounts looks like it's been forced out of true; not torn or badly damaged, just off-kilter.  So one of my first jobs is to take the frame to my engineering guy and get him to sort what needs sorting and check the geometry over.
Meanwhile, plenty of time is being spent on researching and locating missing/bent/busted parts.  Jesus, eBay's making buying stuff from over the pond expensive.  I know insured post is probably(?) the right way to go, but this is getting silly.
« Last Edit: May 30, 2011, 12:20:52 PM by the-chauffeur »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #29 on: May 30, 2011, 06:13:32 AM »
your last bike turned out beautifully, I will look forward to following this one.
My second motorcycle when I was a teenager in the early 80's was a '71 SL175. I've been thinking that an SL350 might make for an interesting light duty adventure bike.
« Last Edit: May 31, 2011, 08:05:25 AM by Bankerdanny »
Offline UK Pete
« Reply #30 on: May 30, 2011, 12:04:03 PM »
Hi Neil, thats an interesting bike you have got yourself, pm me we will have to meet up, perhaps i can come over and see your new bike
Pete
« Reply #31 on: June 01, 2011, 03:00:09 PM »
Hey Pete - yup, it's interesting alright.  I'll be in touch soon.  Meantime . . .
Teardown (cont'd)
Finished breaking the bike down into its component parts, and then smaller bits from there.  Did I mention the state of some of the bits and pieces like carbs and air filters?  You can tell it was a field bike:
The photo doesn't really show just how bad these carbs are.  Completely gunged and with bits missing/broken.  I somehow doubt they're recoverable, so I picked up another set from a guy in Germany, only to find that they were locked solid and obviously hadn't been moved - let alone used - for a very long time.  All four were soaked in coke, then paraffin but no matter what I did to them, they still looked awful.  The filters and end caps were a little better:
Fortunately, most of this stuff is mud; there's some corrosion, but it's not terrible.  As for the seat, I got the one off the bike and found a second being sold by the same guy as supplied the second set of carbs.  Neither were great, and both seat bases have small cracks in the same place along one edge.
And I was right about the mouses.  This is what remains of the foam in the one that came with the bike:
Little sods.
Right now, the engine outer cases have gone off to Dale the polish for refinishing.  As with the other bike, I've decided not to paint the engine - instead Dave the vapours has got the crankcases, head and barrels, along with various carb bits, pistons and valves.  He's a top man for vapour blasting, and I'm hoping his work will save me some cash in internal parts.  Meantime, Brian's got the frame to sort out the wonky yoke stop and stuff like the botched footpeg mount.  He's also got the seat pans to weld up, and he's already removed the bolts holding the sprocket to the camshaft - weirdly, they had either been staked in place, or were held in with some hardcore threadlock which none of my spanners could shift.
Lots of hurry up and wait on the horizon . . .
« Last Edit: June 05, 2011, 08:48:21 AM by the-chauffeur »
« Reply #32 on: June 01, 2011, 03:14:13 PM »
Exhausts
After the initial euphoria that the pipes were basically sound had worn off, I had a good look over them and found that they weren't quite as hole-free as I had thought.  Unsurprisingly the drain plug bolts have never been taken out, and as condensation has collected around them it's caused some rot - not much, but enough to cause the outer skin to tear when I gave one of the drain plugs a hefty twist.  Nobody likes to see this sort of thing:
Bear in mind these images are very close up - the actual damage is about 1in in length.
It seems to run mainly up the seam - there's not really much in the way of rot to the main body, and unlike the set on my K0, the baffles are almost entirely intact.  These have also gone off to Brian so he can drill out the drain plugs and a couple of other screws and then get busy with the TIG on them . . .
 . . . he says . . .
« Last Edit: June 01, 2011, 03:16:34 PM by the-chauffeur »
« Reply #33 on: June 03, 2011, 12:39:31 PM »
Shiny new things interlude pt.1
As I said, nobody likes to see rust holes in parts, so by way of balance, here's part of an order that turned up from David Silvers this morning:
Not bad, huh?  These were the cheap bits - no really.  The ones below are what makes builds like this expensive - not only because there are a bunch of them, but because grey cables seem to be horribly pricey.  This little lot made up about a third of the overall cost of bits (which included lots of rubber bits and pieces and petcock rebuild-type stuff) . . .
What you're looking at are cables for clutch, front brake, tacho, speedo, and throttle, together with the brake light activator cable/switch.  Almost all of the ones on the bike were fried, dried, or cracked so other than buying a combination of black and grey cables, I didn't have a lot of choice other than to buy NOS . . . but ouch, really ouch.  The only one missing from the set is the rear brake cable - NOS ones are pretty much unobtanium, so I've got a half decent secondhand one on backorder.
Next up is the order for the engine bits.  Fortunately there's nothing too horrendous needed there - camchain, tensioner/rollers, a couple of carb rebuild kits and other funky switchy-type parts.  I'm also hoping valve springs can still be ordered from the big H (there's some conflicting information as to whether they can or not).  Having said that, I'm leaving that order until some of the parts that have gone out for work start to make their ways back.  I've made the mistake of multiple orders in the past, and only later worked out just how much I'd wasted in delivery costs . . .
Moving on . . .
« Last Edit: June 03, 2011, 02:27:45 PM by the-chauffeur »
« Reply #34 on: July 21, 2011, 12:00:58 PM »
Quick update
Annoyingly, progress has been slow.  Frustratingly, all of the people I'm relying on to do engineering/paint/polish type work are taking w-a-y much longer than is necessary, and for no good reason I can understand.  Six weeks on, and the engineering shop I took the frame to hasn't even started work on it.  Polishing is 'nearly there' and paint has had to go back for some rework, but without the frame, I'm not going anywhere fast.
However, vapour blasting is completed and so I've got some engine parts back.  The bottom end is back together, but there was a problem with the cylinder bores, which meant I needed to swap them out, and the replacement bores turn sit about 1/2mm proud of the top of the cylinder housing.  I'm getting them checked 'cos I think they'll need milling flat.  At the same time, vapour blasting revealed one of the spark plug holes had been mashed, and only has a couple of turns of thread left in it.  That needs addressing, too.
So for now all I've got is another image of NOS kit:
Lots of odds and sods. Still looking for a decent tach, though.  Them's hard to find.  And after plenty of work, the carbs now look like this:
When I say plenty of work, I mean vapour blasting, ultrasonic cleaning, replacing jets/washers/o-rings and soldering holes in the floats.  For varioous reasons, I ended up buying 3 sets of carbs and only got one good float out of all six individuals.  How's that for a poor hit rate?
And this is what the solder looks like (after it's been put on and flatted down:
More to come . . . eventually
Offline UK Pete
« Reply #35 on: July 22, 2011, 09:57:05 AM »
Yep thats something we all like to see NOS parts, and them carbs look amazing, your attention to detail is very good,
i would take my business elsewhere with that engineering shop 6 weeks is taking the piss
Keep at it mate
Pete
Offline Really?
« Reply #36 on: July 22, 2011, 10:07:05 AM »
Fantastic!
The Wife's Bike - 750K5
The Kid's Bike - 750K3
« Reply #37 on: October 08, 2011, 04:24:38 PM »
Progress has been much slower than I'd anticipated - but that's how it goes when you're reliant on unreliable suppliers.
Anyways, we're getting there . . .
Engine and exhausts are going to take another month or so.  Just gotta be patient.
« Reply #38 on: October 20, 2011, 11:45:47 AM »
So the wheels and handlebars are done.  I was gonna use the 'bars that were in the previous pictures (NOS CL77's) until I realised they were about 2in narrower (end-to-end) than the SL's.  That 2in is fairly crucial when it comes to mounting switchgear, so I picked up a set of standard scrambler 'bars and modified therm to take the wiring . . .
Question for anyone who knows about these things - the front brake cable seems a little short; it fits . . . just, but is too tight to feed up through the chrome clip on the handlebars.  Is that right, or have I been sent a cable from an earlier model?
« Last Edit: October 20, 2011, 11:50:53 AM by the-chauffeur »
Offline Roach Carver
« Reply #39 on: February 25, 2012, 04:33:11 PM »
I just bought one of these. Same color as yours i think. Watching for inspiration.
« Reply #40 on: April 03, 2019, 01:34:05 PM »
Seven years and one house move later . . .
Yeah, we kinda got there in the end.  As it so often does, life got in the way a bit, and so I had to put a whole load of things on hold.  This photo was taken only a couple of weeks before I moved house (late 2012), and after that, well, nothing much happened for a long time.
The engine rebuild/reinstall went pretty much the same as the K0, and I had the same head-to-barrel joint leak caused by not getting the cylinder studs set to the right height.  Pulled the engine back out, put that right, and we've been fine ever since.  I have a feeling that when I pulled the K0 engine, I replaced the camshaft with a later (or CB350) version, although I can't for the life of me remember why right now.  I think it was either something to do with weight reduction - the K0 camshaft is a big ol' lump - or to change the way the bike revs (an on-road set-up is more practical than off-road, esp. given the sheer weight of the K0) but essentially this makes both engines pretty much the same as eachother.
One job I did do in the interim was re-lace the wheels with stainless spokes.  It's all back together now, but one of the wheels is a little out of whack, and I've got to sort out some vibration that shouldn't be there.  I've also found repro rear brake cables for both SLs (parts I've long wanted to swap out) so I'll replace them when I get time.
At some point, I might update this thread again with some comments on the real world differences between the two.  And maybe, just maybe it won't take me another seven years . . .
Offline jgger
« Reply #41 on: April 03, 2019, 08:59:32 PM »
Beautiful job. I have always liked the look of those things. Brings back memories of a much freer time in life!
Offline MoMo
« Reply #42 on: April 03, 2019, 09:28:15 PM »
Very nice 8)  Larry
Offline ChromeDreams
« Reply #43 on: April 05, 2019, 10:37:40 AM »
looks incredible! that paint scheme with the frame is really something to behold, super cool combination there
« Reply #44 on: April 05, 2019, 04:49:54 PM »
Thank you folks - you're very kind.
A couple of other things I've remembered since the last post . . .
- the pins in the K0 cush drive are specific to that bike.  Given that it was a one year only model, that seriously limits rear sprocket options.  IIRC, the issue is not the geometry/placement but the diameter of the threads the sproket mounts to.  You can significantly increase your sprocket options for not much money by switching the pins to the K2 versions, which I think are basically the same as the CB/CL350 pins (I guess I should add a disclaimer at this point - a 7-year hiatus between posts has made my memory of the exact change I made a bit hazy; I've posted on this subject somewhere else, but can't find exactly what I said/did right now - so if you're thinking of doing this, don't take this as gospel and do your own research.  Just know that the pins can be changed and that change is a better option than trying to modify the sprockets . . .
- the float bowls of the Keihin carbs that Honda used across several of its ranges (early 70's era) are very similar.  Whilst the jets tend to vary quite widely, I've found that the float valves, floats and bowl gaskets are often interchangeable.  From my experience, this goes for the CA/CB/CL77, the SL350 K1/K2 and the CB750 K2, all of which seem to have the same basic carb setup (the SL350 K0 uses the same carbs as the CB/CL350s, so there's options there, too).  Original part numbers seem to vary, but the posts the floats fit between seem to be standard.  And that's a good thing if you're working on a budget or like me, find one too many pinholes in the old brass floats.  Unless you're going for a concourse/showroom resto or museum quality, go for aftermarkets.  Places like Sirius Consolidated Inc sell decent plastic floats that I've found to be just as good as the originals but without the fragility - or cost - of NOS bits.  And you can get four aftermarket CB750 K gaskets for less than half the cost of one CA77 original.
- not all powdercoat finishes are equal - or at least, I don't think they are.  The finish on my K0 frame is a flat grey; the K2 has a bit of a sparkle in it.  The flat finish seems to me to be more durable and less fragile than the sparkle version.  Again, that could just be me, but I'll be sticking to flats from now on
- be careful who you buy spokes from.  I had two sets of spokes sourced from overseas, and the bends at the button ends were out by a couple of degrees.  Doesn't sound like much, but it's enough to make the wheels pretty much impossible to lace.  In the end, I had to order some custom spokes using originals as patterns.  Worked out fine in the end, but if I'd've known the headaches I was going to have, I would have gone straight for the customs
- like anything else, don't assume NOS clocks will work the same way as others from the same era.  I've spent the last few years cursing after having spent a small fortune on the K2 speedo and finding out too late that there's something not right with the trip - it doesn't work.  Or at least, that's what I thought . . . right up to the point I bought an XL350 (yeah, I know) and played with the trip on that bike.  Like the SL clock, I couldn't get the trip knob to engage but then something in my brain said try pulling it out (like you would to adjust the time on an analogue watch).  And just like that, I'd solved the non-working trip issue; it had worked all the time - I just didn't know how to operate it.  If only I could afford a K2 owner's manual, I'd've known about that much earlier
- horns can fail in very odd ways.  Late 60's horns are mechanical and work on the same principle as ignition points.  Some of them can be disassembled, but the points themselves are very small and it may not be worth trying to clean them up
- depending on the quality of the surfaces it's applied to, ceramic coating may not be as durable as the marketing materials suggest.  I had the K0 pipes coated and whilst the silencers have held up fairly well, the same can't be said of the downpipes.  They're developed a rough texture and at some point I'll need to flat them off and paint them again.  I can see this maintenance turning into yet another annual ritual I could really do without . . .
- if you're at a gas station and filling a tank that's recently been painted, always put the bike on the side stand and stop before you get to the top.  If you fill to the brim with the bike upright, there's a very good chance that it'll be over-full when you put the bike on the sidestand, and that's a good way to end up with fuel running down the side of the tank . . . which leads me on to . . .
- . . . no matter what you do to them, modern paints are no match for modern fuels if you get any onto a seam.  I filled the tank of the blue bike whilst standing upright, put it onto the sidestand to go and pay for the fuel and came back to find a) a small puddle under the bike and b) paint bubbles around the neck of the tank.  Not terrible, but a bloody nuisance.  I've made a rubber gaiter out of an old innertube to hide the offending mistake
- Hondaman's ignitions are a great investment, but you already knew that, right?
And finally, YouTube resources have come a long way since my original posts on this thread.  In addition to this excellent investigative work on rubber revival:
there's some very good videos on improving the charging systems of the the older Hondas.  Whilst I haven't tried it yet, I'll be doing this mod to my bikes in the coming months:
As I said, I've started work on a CL77, and now I've got something to compare the others to, it's fascinating to see how Honda developed its bikes throughout the mid-60's/early-70's.  With hindsight, there were some really strange design choices in the earlier years that were refined out due either to manufacturing/upfront cost, warrantee claims or advances in technology.  Three piece camshafts, anyone?  So maybe I'll start another thread to document the CL . . . and the CA that'll follow hot on its heels.
« Last Edit: September 21, 2019, 12:23:13 PM by the-chauffeur »
Offline jgger
« Reply #45 on: April 05, 2019, 08:17:55 PM »
Do it! I love the old CL's. My CL 72 was the first "Big bike" I ever owned, and still have what's left of it.250cc of unique sound and one of the most awesome lookers Honda ever built.
Some day it will go back together.
