Author Topic: engine makes large clunking sound when trying to start....  (Read 5890 times)
Offline beks82
« on: July 24, 2010, 07:11:45 PM »
Hey guys 76 750F, I got it to start after reassembly but when pressing the starter button to start her up once in a while I'll hear this loud clunking/rattling noise...was wondering if this was normal or not...
Offline vern401
Re: engine makes large clunking sound when trying to start....
« Reply #1 on: July 24, 2010, 07:32:48 PM »
No it is not.. can you get a file of the noise for us? Maby one of us would be able to ID it for you.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
Offline beks82
« Reply #2 on: July 24, 2010, 10:48:31 PM »
don't know how to upload recordings online....but i  guess the best way to describe it is it seems like something engages inside of the motor very harsh, which is the large clunk almost.  Then a whirring, and it seems as the engine is not being engaged.....
Offline Hush
« Reply #3 on: July 24, 2010, 10:56:08 PM »
Sounds like a starter clutch, can you check the starter motor is bolted on tight?
Offline Spanner 1
« Reply #4 on: July 25, 2010, 07:21:24 PM »
Hush plus one.
« Reply #5 on: July 25, 2010, 07:25:49 PM »
Yep, starter clutch, probably the three 8mm phillips screws are loose. Buy some good 8mm "Unbrakos" and strip your starter clutch, inspect the rollers and springs, and re-install it with the new screws, and it should be fine. Cheers, Terry. ;D
Offline beks82
« Reply #6 on: July 26, 2010, 03:29:30 AM »
thanks guys for all the replies.  strange thing is today there were no problems, checked the starter motor and it's on their good and tight.  is it possible that a starter clutch would slip out if a battery was undercharged?  I have inkling that i may need a new battery....
Offline Hush
« Reply #7 on: July 26, 2010, 02:11:10 PM »
No I doubt it is your battery.
Offline beks82
« Reply #8 on: July 27, 2010, 12:29:53 AM »
okay, so then I'm stuck on the starter clutch, does it need to be replaced or can i just tighten down the bolts and be done with it?
« Reply #9 on: July 27, 2010, 04:51:33 AM »
You'll need to remove your rotor to check it mate, quite often the screws will be damaged, so it's best to buy 3 new 8mm unbrako's. Also, look for damage to the starter clutch's outer steel case for damage, I've seen rollers bashed back so violently they've been shoved up through the outer case. Also check that the little springs are intact, they take a pounding too. Cheers, Terry. ;D
Offline kenolds
  • Before the Dismantle
« Reply #10 on: July 27, 2010, 06:52:01 AM »
Sorry you are having trouble with the starter clutch.  If you want to see what a fully functional assembly looks like, then just give me a call (Ken from Alpharetta).  I would also like to see your bike and maybe help you troubleshoot.
Best of luck,
Kenolds
Parts, Parts, Everywhere - But Not A Bike To Ride.
