Author Topic: 72 cb500 start button troubles???  (Read 2561 times)
Offline scooter1
  • 1973 cb750
« on: July 25, 2010, 09:32:19 AM »
Ok here's whats going on.....I removed the right hand controls because the electric star would not work when I pressed the button.  When I touch the yellow/red wire to the bars to ground it out I'm getting spark....and the starter will not spin!!
 If I cross the pos/neg on the starter solenoid it will start.....do I have a bad ground???
Im not that good with the electrical stuff, any help would be appreciated!!!
Offline scooter1
  • 1973 cb750
Re: 72 cb500 start button troubles???
« Reply #1 on: July 25, 2010, 12:58:04 PM »
Offline vern401
« Reply #2 on: July 25, 2010, 01:38:15 PM »
try running a jumper wire from the small wire on the start cylenoid to the + treminal on the battery. if it spens the motor over then the cylenoild is ok.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
Offline Accolay
« Reply #3 on: July 25, 2010, 01:45:43 PM »
Yeah, I'd check the starter solenoid too. It sounds like your Yellow/Red wire has continuity to the starter switch, but your switch isn't switching. I'd take some voltage checks just to make sure though.
1977 CB550F
Offline vern401
« Reply #4 on: July 25, 2010, 01:49:40 PM »
that would be the next thing back in line. some rubbing alcohol or contact cleaner may help get the switch to working again.
1972 SL350
1978 750F SS
1979 XC500 Custom
1991 ZX600C4 Ninja
1982 KZ550C-3
Offline scooter1
  • 1973 cb750
« Reply #5 on: July 25, 2010, 06:15:05 PM »
ok the solenoid has the big - wire and the big + wire and a small red wire connected to it.... and a small yellow/red wire and a small black wire.
by jumping the small wire to the + which one are you referring to......yellow/red or small black???
thanks for your help
jesstineo
« Reply #6 on: November 02, 2010, 04:20:56 PM »
what ever happen to your starting issues, ian having the same problems and i need help i cant figure it out at all even the horn does not work but the horn work when i hook it up to the battery.need help on starting the bike with the start button thanks
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #7 on: November 02, 2010, 04:37:23 PM »
When you toch the yellow/red wire to the bar you get spark. Where do you get spark? Spark plugs, from the wire, or another area?
The starter button on 500 grounds to the bars. It will not work unless the control pod is fitted to the bars tightly,so it can grgound to them.
We'll move onto the starter solenoid after the above question is answered.
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
