Author Topic: Learn from my mistake!  (Read 3429 times)
Offline Spanner 1
Re: Learn from my mistake!
« Reply #25 on: July 27, 2010, 05:08:52 pm »
If the jugs will lift off the crankcase, at least you can feel in to the bottom of the guide/pin to confirm it's not there , yes/no?
Offline egar
« Reply #26 on: July 27, 2010, 05:18:37 pm »
I know it isn't there. It was in the baggie with my cam tensioner. But I need to separate the two heads because the valve guide has a pin on the top that locks into place between the valve head and cylinder head.
sohc4
'04 ST1300, '70 cb750KO
Offline Spanner 1
« Reply #27 on: July 27, 2010, 05:28:45 pm »
Duh!, I had forgot that the 'plastic' pin drops into the top slot first, which is indeed between head and cylinder block!
Offline egar
« Reply #28 on: July 27, 2010, 06:16:30 pm »
Spanner,
Exactly! All I need to do is get the heads apart, slip the cam chain guide in it's spot and put the top end back together. I am sooo close.
sohc4
Offline 1974blaze
« Reply #29 on: July 27, 2010, 06:27:52 pm »
i had a girlfriend for 7 years.  almost married her.  didn't. had a long painful expensive breakup.  cheaper than divorce and now i'm happy with someone else.
moral of the story???? better to find out now, then when you're way down the road with nowhere to go.
this is gonna be a lovely rebuild and you're gonna be a wise man. ;D
Offline egar
« Reply #30 on: July 28, 2010, 05:01:33 am »
Thanks, blaze. I'm so frustrated trying to find a way to separate these two heads. I hope the bike actually does run when I finish it.
sohc4
