Author Topic: throttle cable length/query about earlier post  (Read 1449 times)
Offline Captaindonutbikes
« on: July 30, 2010, 09:06:49 AM »
http://forums.sohc4.net/index.php?topic=62696.0
i have the same problem with the cr cables but i am bit confused about the actual answer.
the cable is about an 30mm too long with the standard cables on the acewell bars.
would the kle650 throttle cable set work or custom length from allens ?
cheers peeps
Re: throttle cable length/query about earlier post
« Reply #1 on: July 31, 2010, 08:17:18 AM »
BUMP  ;D
