Author Topic: inner tube help  (Read 882 times)
Offline kajtek
inner tube help
« on: August 03, 2010, 03:42:49 PM »
hi all,
need a little advice regarding innertubes. changing both front and rear tires for the first time so obviously a good idea to do the tubes aswell.
its a cb400f with 90/90 18 and 100/90 18 tires. im thinking the best route is a 3.00 x 18 tube and a 3.50 x 18 tube, or tubes that are in the same metric sizes. only thing is theres a few types so cant decide which.
looking around i found these:
http://cgi.ebay.co.uk/NEW-2.75-x18-%26-3.00-x-18-in-HD-INNER-TUBE-FREE-RIM-TAPE_W0QQitemZ380163384331QQcmdZViewItem?rvr_id=119635728035&rvr_id=119635728035&cguid=6e0b90a51270a0e205361d36fef83beb
hd tubes that are for road and off-road use. is this a bit overkill?
or should i be looking at something more like this
http://www.tyresalesuk.co.uk/cgi-bin/engine.exe/productsearch?Cat=7&Man=3&Fit=U&Size=18&Page=5
if it makes any difference im fitting avon roadriders.
thanks for any help:)
ashley
1978 honda cb400f supersport
Offline Frankenkit
  • Industrial Strength
Re: inner tube help
« Reply #1 on: August 03, 2010, 03:46:50 PM »
As long as the tubes are sized to be the same as the tires you're putting in, you'll be fine.
If you're mounting your own, what really helped me out with the new tubes was putting some baby powder in a plastic shopping bag and shaking the new tube around in the bag to coat it with the powder.  Slipped right into the tire and seemed to avoid the tire irons pretty well.
2012 CBR250R "Black Betty"
1980 CB650c- (sold) Delilah
1973 CL350- Lola?
Stuff for sale
KingCustomCycles.com
Re: inner tube help
« Reply #2 on: August 03, 2010, 03:55:05 PM »
Sounds like you might be over thinking this.  I get Chen Sheh tubes from JC Whitney for $7-12 and use their online recommendations for sizing.  I replaced roughly 125 tubes and tires with no problems.  Remember new rim strips. :-)
Offline Frankenkit
Re: inner tube help
« Reply #3 on: August 03, 2010, 04:00:26 PM »
some also use duct tape.  As long as it thoroughly covers your spoke nipples you should be ok.  Maybe take a bit of time w/ a dremel or wire brush to get rid of some of the rust you'll inevitably find, too.
1973 CL350- Lola?
Stuff for sale
Re: inner tube help
« Reply #4 on: August 03, 2010, 06:41:07 PM »
good advice
Offline kajtek
Re: inner tube help
« Reply #5 on: August 04, 2010, 01:09:35 AM »
thanks for the advice, maybe i am overthinking a bit! im just a bout to take my first motorcycle trip (london to paris) on my 400 and trying to make sure everything  is ok..
good point about the rust inside, im gonna clean/polish the rims and hubs while they are off so good time to clean the inside of the rim.
thanks for the baby powder suggestion, i also read somewhere that theres less chance of pinching the tube if you use a smaller one (i.e 3.00-3.50 tube in a 3.50 rim as opposed to a 3.50-4.00 tube), also a little air in the tube apparantly helps too.
ive mounted many bicycle tires, this is my first motorcycle, wish me luck!
ashley
Offline Frankenkit
Re: inner tube help
« Reply #6 on: August 04, 2010, 01:47:11 AM »
there are several guides on youtube, but basically, to avoid pinching your tube, put just enough air in it to give it some shape, so if you hang it on your finger, it'll crease over it.  That way you have enough air that it'll keep its shape and not twist on itself, but not so much that you can't cram it in the tire.
1973 CL350- Lola?
Stuff for sale
