Author Topic: your own recording studio  (Read 914 times)
« on: August 03, 2010, 09:25:45 PM »
I was looking at some new small amps today, fender 15 and 30, and thinking would I use the hi tech bells and whistles. I have a laptop just for the race car data and weather station so there is one I could plug in to play along with and record myself as I learn. Does anybody use something like this and could you post your music here?
Offline simon#42
  • liverpool
Re: your own recording studio
« Reply #1 on: August 04, 2010, 10:56:24 AM »
i use apple garageband , almost pro quality for not much money , very easy to use , have a quick look and see if its the kind of thing your after don
Offline gerhed
« Reply #2 on: August 04, 2010, 12:30:54 PM »
I too use Garage Band--Apple only, I think.
I just got a new Fender 25W amp.
Works fine--
Cheap and red!
http://i170.photobucket.com/albums/u251/gearheaded_photos/Mroom.swf
« Last Edit: August 04, 2010, 12:32:58 PM by gerhed »
          83 XL600R in CB360 Frame
Offline lowflyingdutchman
« Reply #3 on: August 04, 2010, 06:21:04 PM »
have used audacity. Free multitracker with some good results. Using a portable roland digital recorder now. Bugera v22 amp. Nice and warm.
May the Fours be with you.
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #4 on: August 07, 2010, 01:38:52 AM »
You've got a lot of options. Fostex, Tascam, Roland, and others make some great standalone digital multitrack recorders. You can also go the Digital Audio Workstation (DAW) route, which means buying audio software and using your computer as the brains of the outfit. I use Cubase and Logic Pro on my Mac DAW, but there are LOTS of choices out there. Be prepared for a steep learning curve if you go this route; the software is very powerful but can also be very complex unless you're already experienced with digital recording.
Either of those two routes will provide plugins that can replicate the sound of nearly any guitar amp at the click of a button. Amp modeling has come a LONG way in the past few years; it's gotten to the point where I can't tell the difference between a real amp and a plugin in a blind test. I record everything direct now using plugin amp modeling. If you go with a standalone digital recorder and it doesn't have built-in amp modeling, you can always use a Guitar POD (standalone amp modeling device) between the recorder and your guitar.
If you're just going to be screwing around you'll probably do best with a small multitrack recorder. Easier to learn to use for a novice and they can do great things in the hands of someone who knows what they're doing. A lot of bands out there have recorded entire albums on cassette 4-tracks.  ;D
Here's a link to get you started: http://pro-audio.musiciansfriend.com/recording/multitrack-recorders
If you'd like to listen to some of the stuff I've written and recorded over the years, click this link: www.kettletriggermusic.com/Audio
–Captain Horatio Hornblower
www.thehairynickel.com
« Reply #5 on: August 07, 2010, 09:23:42 PM »
Thanks for the info, I'm totally new at music and just want to goof around with it. I'm listening to Kettletrigger now. I like it, really cool.
