Author Topic: Current '66 Mustang Coupe Work  (Read 1000 times)
Offline wannabridin
  • Patience made me a
  • -Garrett
« on: August 06, 2010, 07:23:16 AM »
So guys, my good friends fiancee asked me to drive them off in their wedding sept. 10, so i decided to use that as an excuse to do some MUCH needed work on the old girl.  here's what i have planned:
new clutch and all that goes with it
rebuild shifter and upgrade bushings
Open Tracker clutch rod linkage
new D&L 3-4 shift collar, gear dogs, HD shift forks and new seals
new transmission bushing
oil pan gasket
new valve covers w/ wing bolts
full tune up (cap, rotor, wires, plugs, air filter, oil change)
Street or Track HiPo fan shroud
paint engine bay (w/ motor still in there!) there was an article in mustang & fords on doing this in a torino!
remove factory export brace
Arvinode mufflers and resonators and enlarge louvers on trumpet tips
port match, blast and repaint manifolds w/ new exhaust donuts and gaskets
Bilstein shocks w/ chrome shock caps
1" front sway bar
5 leaf rear springs
UCA drop and roller spring perches
CJ Pony parts full front end rebuild kit (new upper & lower CA, tie rods, sleeves, etc.)
Open Tracker roller idler arm
Humphugger console
remove a/c
new side seat moldings and sill plates
new seat belts, dash speaker and package tray
i have a 289, edelbrock 600 4v, edelbrock performer 289 intake, electronic ignition, dual exhaust w/ h-pipe, front disc brakes, t-10 4 speed.
here's a link to the current progress of the work.  i'll add more pictures as i get them...  http://picasaweb.google.com/106056913584549886552/MustangWork0710?feat=directlink
let me know what you guys think!!  i think she's going to handle on rails compared to the old suspension.  gas adjust shocks up front, worn out front steering and suspension components, VERY old and sagging rear leaf springs and air shocks...  all in all i think this is going to make her a LOT more fun to drive!   ;D
« Last Edit: August 06, 2010, 07:26:25 AM by wannabridin »
Offline boatsdickson
  • 1978 836 K8
Re: Current '66 Mustang Coupe Work
« Reply #1 on: August 06, 2010, 04:10:58 PM »
Sept 10 of this year? Thats quite the list of fixes to tackle. But yeah its going to be a great project. Good luck.  8)
"No. We're all our own prisons, we are each all our own wardens and we do our own time. I can't judge anyone else. What other people do is not really my affair unless they approach me with it. Prison's in your mind. Can't you see I'm free"?  Testimonial of Charles Manson
Offline wannabridin
  • -Garrett
« Reply #2 on: August 07, 2010, 04:15:22 PM »
yup, sept 10th, as in just over a month from now...
ARG!!  painting is a #$%*!  i haven't even tackled the engine bay yet!!  once i get the engine bay done, i think it'll be a lot smoother going...  still don't wanna do it though............................................................  oh well, my spray bomb results are pretty good so far!   ;D
