Author Topic: Where do I get a replacement sealed beam headlight for my 80 cb650c?  (Read 923 times)
Offline manjisann
To my dismay I found out my high and low beams appear too have burned out on my headlight. I would like to know where I can get a stock style replacement for the headlight? Sorry, my search fu has only turned up info about Halogen and HID or H4 upgrades (does anyone know what type of bulb was used in this bike and what the energy ratings were?) I'm just trying to get the least costly replacement that will function properly.
Thanks,
Brandon
1980 CB650 Custom
Offline dusterdude
Re: Where do I get a replacement sealed beam headlight for my 80 cb650c?
« Reply #1 on: August 06, 2010, 06:14:28 PM »
im guessing it uses the small round sealed beam,if so,you can use the automotive bulb h4656(i think).you may have to cut another goroove in your bucket,most bikes used 2 grooves and cars used 3,but it wont be a problem
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Tintop
« Reply #2 on: August 07, 2010, 07:21:43 AM »
the stock headlight (seal beam) was rated 45W / 55W.  the H4 Halogen is 65W high beam.  the halogen draws to much power for the older 550's, puts it right on the edge (HID is rated at 35W, my solution but $'s).  you should be able to p/u a seal beam from any bike shop (these are 7" vs auto 6").
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline manjisann
« Reply #3 on: August 07, 2010, 10:20:18 AM »
I checked my clymer and it says the headlight was a 65/50w so the Halogen or H4's seem to be in order, so I may just pick one of those up. I need to double check and be sure it really was the headlight that went out and not something else.
Anyone have any experience with this one?
http://www.jcwhitney.com/7-xenon-high/low-motorcycle-headlight/p2014567.jcwx?filterid=c52717d8782y1980j3#
Thanks,
Brandon
1980 CB650 Custom
Offline manjisann
« Reply #4 on: August 07, 2010, 10:34:27 AM »
SWEET, I just found a headlight on Z1, has anyone ever used one of these?
Brandon
1980 CB650 Custom
Offline Gordon
  • 750K1, 550K2
« Reply #5 on: August 07, 2010, 10:38:27 AM »
That's probably a good idea since the hi and low beam don't typically go out at the same time.  You already replaced the fuse?
Offline manjisann
« Reply #6 on: August 07, 2010, 11:40:06 AM »
I haven't had a chance to check much of anything been busy with a few other things unfortunately. I don't think it's the fuse since the low wasn't working and then I switched it to the high and after a minute it was out as well. I will check the fuses though, and I was thinking I'd check the wiring. Can I measure continuity across the connectors on the light to ensure it's really blown?
Thanks,
Brandon
1980 CB650 Custom
