Author Topic: Coils source  (Read 2806 times)
eldar
Coils source
« on: February 21, 2006, 04:55:16 PM »
I am looking to get some coils. Now the place I want to go is out of stock. yeah great. I want to get cb900 style coils. Anyone know of a site that is cheap like under $50 per coil? Not going to bother with accel or dyna, expensive and I use points anyways.
Offline scondon
  • Mmmm......tasty bugs
Re: Coils source
« Reply #1 on: February 21, 2006, 11:46:59 PM »
partsnmore has cb900 coils listed at $26 each(currently out of stock...lightbulb in head brightens...."Oh, you probably knew that").
BikeBoneYard is parting a '80 CB900. Coils listed at $25/each and probably include plug wires(bonus)
http://www.bikeboneyard.com/80%20cb-900.html
BikeBandit will sell ya the whole set-up for only $290. Wonder how they got their name.
http://houseofmotorcycles.bikebandit.com/partsbandit/oem_schematic_view~schem_dept_id~177595~section_dept_id~1~section_dept_name~OEM+%28Stock%29+Parts~dept_type_id~2~model_dept_year~1980~model_dept_mfr~Honda~model_dept_id~174429~model_dept_name~CB900C.asp
Wow, that FAQ vendor list is full o' good stuff :)
dec505
Re: Coils source
« Reply #2 on: February 22, 2006, 02:08:25 AM »
I have a set of DC8-1 Dyna coils if your interested that are still in the box and have the warranty and everything. They have never been put on a bike and I paid over a 160 bucks for them from Dyna. I would sell them to you for 125.00 if your interested. There made for points. 5.0 ohm primary and 14,000 ohms secondary.
eldar
Re: Coils source
« Reply #3 on: February 22, 2006, 08:44:19 AM »
I will check on info for those coils. I am only running points right now so that might be overkill but the 5ohm primary matches good. I will let you know. Gotta clear it past the warden too!
Offline DrMark
Re: Coils source
« Reply #4 on: February 22, 2006, 10:09:23 AM »
I bought my last set of CB900 coils on EBAY for about $15.  Then purchased bulk spark plug wire and caps from my local dealer. Total cost: $30. Mounted them on a 1978 CB550K3. Also running a Dyna-S ignition system
1978 CB550K
1983 CB650SC Nighthawk
eldar
Re: Coils source
« Reply #5 on: February 22, 2006, 10:15:37 AM »
Gee you must have gotten lucky on that. I never see any coils I want go for that low. How did you connect the wire to the coil? AS I have not seen these coils, I dont know how they connect exactly. i know they plug in but what TYPE of connection.?
Offline dusterdude
Re: Coils source
« Reply #6 on: February 22, 2006, 11:13:15 AM »
eldar,im going to assume the 900 coil works like the yamaha coils i have on my bike.the coil uses a screw on cap to hold the wire in the coil,so all you do is put the cap on the wire then snip a clean edge on the wire and push into the coil and then screw the cap on.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
theunrulychef
Re: Coils source
« Reply #7 on: February 22, 2006, 11:29:46 AM »
Yeah, they're almost like liquid pressure line connectors w/ a grommet that goes over the line inside the cap.
Beware of getting the cheapo ones, I had one of the screw posts (that you connect the wire to) break off after a few weeks & the place I got them from wouldn't exchange it.  Ate $90 on those f'ing coils.
rook550
Re: Coils source
« Reply #8 on: February 22, 2006, 12:37:06 PM »
Can you replace just the wires on a 77' 550F, if so what kind/brand? my local Honda shop wanted 160 bones for a new one(wires and coil), the previous owner had sliced and diced a set of wires into the old ones...
Zane
Re: Coils source
« Reply #9 on: February 22, 2006, 08:28:27 PM »
Would coils like these work, or are they too modern?   (ebay item # 4609698349)
cd811
Re: Coils source
« Reply #10 on: February 22, 2006, 09:11:59 PM »
i got my dyna coils from www.lowridersbysummers.com $120
i got my taylor pro comp 8mm wires from www.denniskirk.com $24 x 2
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Coils source
« Reply #11 on: February 23, 2006, 05:07:07 AM »
The wires are moulded into the coils, so the only way to replace them is to cut-and-graft.  The CB900 coils (and VFR coils that I have seen used on these bikes) have detachable wires.
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
Offline Clutch Cargo
Re: Coils source
« Reply #12 on: February 23, 2006, 10:00:04 AM »
What kind of spark should you get out of the stock CB900 coils.
CB750 SOHC - 7 to 8 KV - correct?
Mike
1976  CB750K6
1976 GL1000
1994 - ST1100
1985 - HRS21
eldar
Re: Coils source
« Reply #13 on: February 23, 2006, 11:28:18 AM »
THe coils have more output that stock. They are a fairly common upgrade even with points. This is provided that you can run your bike in anything besides stock condition!
